surfek
Hwo to add guest Wifi? (with Mikrotik Cloud Router and hAp ac)
Tue May 22, 2018 11:27 am
I have Mikrotik Cloud Router (doing my LAN DHCP (192.168.9.1/24) and routing, with PCC setup to do load balancing for 2 WAN-internet networks) and connected hAP access point with LAN wireless configured.
I would like to add guest wifi (other SSID with network isolation - no access to LAN, just internet).
On hAP ac I configured:
- virtual access point for guest SSID
- dedicated network e.g. 192.168.99.1/24 with DHCP server for this network
- guest bridge
Network is working (I can connect and obtain IP), but of course there is no internet connection as I am missing this part in my config.
Question how to configure it so guests users from 192.168.99.1/24 network on hAP ac are routed to internet but do not have access to whole LAN (192.168.9.1/24 network)?
Thanks for help,
Michal
2frogs
Long time Member
Long time Member
Re: Hwo to add guest Wifi? (with Mikrotik Cloud Router and hAp ac)
Tue May 22, 2018 1:52 pm
You are most likely missing a src-nat.
/ip firewall nat add chain=src-nat src-address=192.168.99.0/24 out-interface=bridge action=masquerade
set out-interface to the bridge for your main network.
To block access from guest to lan:
/ip firewall filter add chain=forward src-address=192.168.99.0/24 dst-address=192.168.9.0/24 action=drop
Users browsing this forum: Google [Bot] and 70 guests
