alexsolovyev
How to avoid exposing RB version over a wireless AP?
Fri May 25, 2018 1:26 pm
Is there a way to avoid exposing a version number over a wireless AP?
I've tried to put an empty string into "Radio Name" but that did not change anything. The scanner still shows the version number and the flags APRB (A - Active, P - privacy, R - routeros network, B - bridge) for the AP.
pe1chl
Re: How to avoid exposing RB version over a wireless AP?
Fri May 25, 2018 2:11 pm
The scanner uses several techniques to query the radio, like "ip neighbor", "snmp", "SMB" etc.
You need to disable or firewall them all where relevant.
edit: well, that was about the IP scanner. the radio scan may see even more.
R1CH
Forum Veteran
Forum Veteran
Fri May 25, 2018 2:40 pm
This information along with the radio name and model number is directly encoded into the 802.11 beacons - you can not remove it (yet).
viewtopic.php?t=133186
alexsolovyev
Fri May 25, 2018 3:39 pm
Thanks. I hope Mikrotik will add an option to hide this sensitive information.
Users browsing this forum: No registered users and 122 guests
