MUM Europe 2020
dariush03
Do hap lite only work with 5volts power cable?
Thu May 31, 2018 3:58 am
Beacause when i use ither power cables it powers up but when i use the ethernet port it doesnt work or light up
normis
Re: Do hap lite only work with 5volts power cable?
Thu May 31, 2018 11:20 am
Yes, there is no PoE input support. Careful, don't damage it.
Always read specifications and guide:
https://mikrotik.com/product/RB941-2nD-TC
https://i.mt.lv/routerboard/files/15130 ... ini-wg.pdf
jarda
Thu May 31, 2018 11:38 am
Use poe extractor and 5v step down converter.
Users browsing this forum: No registered users and 84 guests
