dariush03
Do haplite only work with 5v power cable
Thu May 31, 2018 4:01 am
Because when i use other power cables it powers up but the ethernet doesnt work or light up how can i resolve this?the original power cable suddenly broke after few power outage . What can i do to make the haplite work again please i realy need your help😔😔😔
chechito
Re: Do haplite only work with 5v power cable
Thu May 31, 2018 7:11 am
try a good quality cellular phone 5v charger with micro usb plug
dariush03
Thu May 31, 2018 7:19 am
I already tried
jspool
Thu May 31, 2018 9:00 am
Well the cable wont physically break due to a power outage. So maybe you had a power surge that fried your power supply. In that case try powering with another power supply of the same voltage and amperage and see if it will work. If it does not then perhaps it was damaged from the power event.
Users browsing this forum: No registered users and 84 guests
