MUM Europe 2020
Equis
Forum Veteran
Forum Veteran
Ram for BGP
Tue Jan 30, 2007 5:14 am
Hello
How much ram is needed for a BGP router?
Will a rb with 64 meg do it?
ste
Tue Jan 30, 2007 11:11 am
Memory depends on configuration. If you need
full routing tables you should have 256MB.
I've quagga running. With two peers it uses 150MB
for bgpd and zebrad alone. So you need some mem
for routingtable, ...
If you just announce your AS and do strong filtering/aggregation
on incoming routes you might find a way to live with 64MB
but it's not worth the work.
So buy a miniitx-Board and throw 512MB on it.
I would use a system of this kind:
http://www.pc-woelfl.de/index.htm?bareb ... _945gm.htm
Stefan
normis
Re: Ram for BGP
Tue Jan 30, 2007 11:13 am
Hello
no is the short answer.
Equis
Forum Veteran
Forum Veteran
Tue Jan 30, 2007 11:18 am
I only need to announce my AS :-)
Users browsing this forum: Kaos1337 and 112 guests
