MUM Europe 2020
Solusan
Simple question (PHP)
Tue Jan 30, 2007 3:09 pm
Does Mikrotik support PHP (hotspot).
Thanks.
tneumann
Re: Simple question (PHP)
Tue Jan 30, 2007 3:30 pm
On the router itself? No.
--Tom
Solusan
Tue Jan 30, 2007 4:56 pm
--Tom
Just HTML & Javascript?
txs
normis
Wed Jan 31, 2007 8:38 am
umm, no! you can't put your own webpages on the router
Solusan
Wed Jan 31, 2007 10:24 am
I see, but.... inside mikrotik i cannot make php pages, just javascript & html.
Is it?
txs
normis
Wed Jan 31, 2007 10:26 am
no, inside mikrotik you cannot store any html,xhtml,php,java,javascript,css,txt or any other files that you want to be displayed on it's webpage.
please explain what would like to do, so that i can give a better answer.
RouterOS is not a webserver of any kind.
Solusan
Wed Jan 31, 2007 10:45 am
oh, sorry, I mean:
Inside hotspot files.
When I try to customize.
txs
balimore
Forum Veteran
Forum Veteran
Wed Jan 31, 2007 10:50 am
oh, sorry, I mean:
txs
yes, i think you can customizing hotspot page as you want...
i did do it... :wink:
Hasbullah.com
normis
inside hotspot login pages you can only use html and javasctipt. basically you are limited to just editing the provided files.
Solusan
Wed Jan 31, 2007 10:55 am
ooookay txs!!!
Solusan
by the way
Wed Jan 31, 2007 10:58 am
Can you helpme with this post?
http://forum.mikrotik.com/viewtopic.php ... highlight=
I'm little bit desperate.... :'(
txs.
samsoft08
Long time Member
Long time Member
Wed Jan 31, 2007 7:58 pm
you can whatever you want with the login page .. just leave the username and password fields as it is or in another place and you can add anything you want.
Solusan
Thu Feb 01, 2007 11:09 am
very many thanks.
Users browsing this forum: Bing [Bot], BlueTechnomage, CZFan, Google [Bot], Znevna and 153 guests
