deltabravo191
Untagged VLAN Access port on hEX
Wed Jun 27, 2018 6:11 am
I have purchased a hEX routerboard to start learning some more about Mikrotik (loving it so far). I had a question regarding setting up a VLAN access port on the hEX. I can get it to send tagged VLAN info to the bridge (does DHCP and lets me hit the internet when I plug a smart switch into it and untag it at that end). But what I cannot figure out is how to get a port to just give an untagged VLAN.
I have messed around in the bridge and interface settings to make the specific port give untagged network but I cannot make that happen. Anytime I plug my PC in it does not give DHCP or internet access.
Thank you so much for your time,
Delta
artz
Re: Untagged VLAN Access port on hEX
Wed Jun 27, 2018 9:46 am
If you want to use your hEX as a router and a switch at the same time, you should follow this guide:
https://wiki.mikrotik.com/wiki/Manual:Switch_Router
deltabravo191
Wed Jun 27, 2018 8:54 pm
Thank you. I have followed a few different guides, along with some help from reddit and it does not seem to be working. Can you take a look at my config:
# jan/02/1970 00:10:29 by RouterOS 6.42.4
# software id = XXXXX
# model = RouterBOARD 750G r3
# serial number = XXX
add admin-mac=CC:XX:E0:B5:XX:XX auto-mac=no comment=defconf name=bridge \
    vlan-filtering=yes
/interface vlan
add interface=bridge name=vlan10 vlan-id=10
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add name=dhcp_pool1 ranges=192.168.10.20-192.168.10.254
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
add address-pool=dhcp_pool1 disabled=no interface=vlan10 name=dhcp1
add bridge=bridge comment=defconf interface=ether5 pvid=10
/interface bridge vlan
add bridge=bridge untagged=ether5 vlan-ids=10
    192.168.88.0
add address=192.168.10.1/24 interface=vlan10 network=192.168.10.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=\
    ether1
add address=192.168.10.0/24 dns-server=1.1.1.1 gateway=192.168.10.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router.lan
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
/system routerboard settings
set silent-boot=no
/tool mac-server
/tool mac-server mac-winbox
chechito
Wed Jun 27, 2018 10:56 pm
to do hardware accelerated vlan you have to use switch
try this guide
viewtopic.php?f=13&t=119383
deltabravo191
Thu Jun 28, 2018 6:53 am
try this guide
Thank you! I read your forum and the hEX does infact use a RB750GR3. I am finding this model specifically does not allow this feature. I emailed support and they sound like they are working on this being a feature in the future. No ETA. Wish I would have known before purchasing, I would have purchased a different router.
Anyhow, thank you again.
chechito
Thu Jun 28, 2018 8:53 am
try this guide
yes, you have to do vlan by software using bridging
update to the latest routeros 6.42.5 bridge implementation is very easy to use
squeeze
Tue Jul 03, 2018 2:55 pm
add bridge=bridge untagged=bridge,ether5 vlan-ids=10
idlemind
Thu Jul 05, 2018 8:20 pm
The only caveat to the previous post is you only can have one VLAN untagged at the bridge. So if you untag VLAN10 at the bridge you will want to tag all other VLANs. If you want an access port for VLAN10, you could also do this:
/interface bridge vlan add bridge=bridge untagged=bridge vlan-ids=1
/interface bridge vlan add bridge=bridge untagged=ether5 tagged=bridge1 vlan-ids=10
Users browsing this forum: No registered users and 98 guests
