Hi Experts,
Diving in to the deep end (for me) with my new hEx.
To replace a GUI based obsolete Draytek.
Looked at various Youtube, and Forum posts for the past 2 weeks, to climb the the 1st rung on the ladder.
Have 2 WAN connections - One is Cable (100M) with DHCP and the Other vDSL pppoe at 60M, serving a single LAN network on 192.168.1.0/24 using the remaining ports.
Ether 1 - WAN1 - Cable DHCP
Ether 2 - WAN2 - ADSL
Ether 3-5 as Bridge1
Wish to Replicate -
1) Balanced use of the WAN, with failover
2) Setup Static IP for some of the devices on the LAN
3) Setup port Forwarding to some of the devices on 2 for IMAP/mail service
4) Setup Dynamic DNS for (3) to work
5) setup L2TP for remote access etc..
-- Have not setup the ntp or set the date and time yet.
Hoping the below is in the right direction, or is there an easier way to achieve what I am after. All the DUAL WAN sdetups seem to be not DHCP based on bioth WAN's. Specially none I have spotted with one Cable WAN and the other as PPPOE DSL WAN. Help please..
Here is my config cobbled from what I have learned so far for (1), Not connected to the WAN network yet..
[admin@MikroTik] > export compact
# jan/01/2002 02:08:03 by RouterOS 6.42.3
# software id = NZMU-EZED
# model = RB760iGS
# serial number = JHDJHSJDHSJ
add fast-forward=no name=bridge1
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether2 name=pppoe-out1 password=dfff user=vodafone
add comment="Lan Network set to 192.168.1.0/24" name=LAN
add comment="Virgin DHCP " name=WAN1
add comment="Vodafone DSL DHCP" name=WAN2
add name=pool1 ranges=192.168.1.2-192.168.1.254
add address-pool=pool1 disabled=no interface=bridge1 name=dhcp1
add interface=ether1 list=WAN1
add interface=pppoe-out1 list=WAN2
add address=192.168.1.1/24 interface=ether3 network=192.168.1.0
/ip dhcp-client
add add-default-route=no dhcp-options=hostname,clientid disabled=no interface=ether1 use-peer-dns=no use-peer-ntp=no
add add-default-route=no dhcp-options=hostname,clientid disabled=no interface=ether2 use-peer-dns=no use-peer-ntp=no
/ip firewall mangle
add action=mark-connection chain=prerouting comment="Load-Balance for WAN1" connection-state=new in-interface=ether1 new-connection-mark=WAN1_conn passthrough=yes
# pppoe-out1 not ready
add action=mark-connection chain=prerouting comment="Load-Balance for WAN1" connection-state=new in-interface=pppoe-out1 new-connection-mark=WAN2_conn passthrough=yes
add action=mark-routing chain=output connection-mark=WAN1_conn new-routing-mark=to_WAN1 passthrough=yes
add action=mark-routing chain=output connection-mark=WAN2_conn new-routing-mark=to_WAN2 passthrough=yes
add action=mark-connection chain=prerouting connection-state=new dst-address-type=!local in-interface=bridge1 new-connection-mark=WAN1_conn per-connection-classifier=both-ports:3/0
add action=mark-connection chain=prerouting connection-state=new dst-address-type=!local in-interface=bridge1 new-connection-mark=WAN1_conn passthrough=yes per-connection-classifier=both-ports:3/2
add action=mark-connection chain=prerouting connection-state=new dst-address-type=!local in-interface=bridge1 new-connection-mark=WAN2_conn passthrough=yes per-connection classifier=both-ports:3/1
add action=mark-routing chain=prerouting connection-mark=WAN1_conn in-interface=bridge1 new-routing-mark=to_WAN1 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=WAN2_conn in-interface=bridge1 new-routing-mark=to_WAN2 passthrough=yes
add action=masquerade chain=srcnat out-interface-list=WAN1
add action=masquerade chain=srcnat out-interface-list=WAN2
/system routerboard settings
set silent-boot=no
/system scheduler
:global newgw [/ip dhcp-client get [find interface="WAN1" ] gateway ]
:global activegw [/ip route get [/ip route find comment="WAN2"] gateway ]
:if ($newgw != $activegw) do={
/ip route set [find comment="WAN1"] gateway=$newgw
/ip route set [find comment="WAN1 routing gateway"] gateway=$newgw
:global newgw [/ip dhcp-client get [find interface="WAN2" ] gateway ]
/ip route set [find comment="WAN2"] gateway=$newgw
/ip route set [find comment="WAN2 routing gateway"] gateway=$newgw
