syadnom
feature request, auto firewall nat rules
Sun Jul 08, 2018 5:22 pm
I'd love for the firewall to automatically open ports matching NAT entries.
If I NAT port 80 in ether1 to an on ether2, I'd like to see a firewall rule dynamically created that is in-interface-ether1, port 80.
Sob
Re: feature request, auto firewall nat rules  [SOLVED]
Sun Jul 08, 2018 5:34 pm
Why? You can already do:
add action=accept chain=forward connection-nat-state=dstnat
It will allow any dstnatted connection, which may sound dangerous but no connection can get this state, unless it's processed by dstnat, so it doesn't open any security holes. What would be the advantage of suggested feature compared to this?
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply.
tomaskir
Trainer
Trainer
Sun Jul 08, 2018 5:35 pm
You can use this FW rule to accept all NATed connections:
Code: Select all
add chain=forward connection-nat-state=dstnat action=accept
EDIT: damn, Sob beat me to it :(
Unimus - configuration management, automation and backup solution
Mass Config Push, network-wide RouterOS upgrades, and more!
syadnom
Sun Jul 08, 2018 5:49 pm
How did I not know this!
Sob
Sun Jul 08, 2018 6:58 pm
It's relatively new (since 6.22, according to changelog). Well, that was in 2014, but still...
Users browsing this forum: No registered users and 79 guests
