Jeanluck
CRS317 - HW. Offloading only works on a single bridge, is it a bug?
Mon Jul 23, 2018 2:03 pm
I have found that the HW. offloading works without problems in the first bridge I created.
However, on the second bridge, under the same conditions as the first, there is no way to activate HW.offloading.
Does v6.42.6 on the CRS-317 only allow active Hw. offloading on a single bridge?
mrz
Re: CRS317 - HW. Offloading only works on a single bridge, is it a bug?
Mon Jul 23, 2018 2:23 pm
Currently yes, HW only on one bridge.
Jeanluck
Mon Jul 23, 2018 2:28 pm
Are you planning to expand it in future versions?
If so, is there an estimated time frame?
chechito
Mon Jul 23, 2018 10:28 pm
make vlans on the bridge to segment your switch, there is no need for multiple bridges
Jeanluck
Mon Jul 23, 2018 10:56 pm
You're right, thank you!
Jeanluck
Tue Jul 24, 2018 11:32 am
I'm not sure how to do it.
I need:
untagged bonding1 <----> untagged bonding2
tagged bonding3 vlan151 <------> tagged port1 vlan151
I had them in 2 bridges because I need them to be totally isolated and I'm not sure how to do it, because there is no drop that I can configure between them.
Could it be enough to use "admit only VLAN tagged" on the tagged ports and "admit only VLAN untagged" on the others?
Users browsing this forum: No registered users and 9 guests
