heavyd
Stale PPPoE
Thu Jul 26, 2018 10:03 am
Hi
Anybody else getting stale pppoe connections ?
V6.40.8
CCR1009
+- 1200 ppp connections
MPLS/VPLS
It happens on random vpls tunnels and random clients.
pppoe-out needs to be disabled and enabled again to reconnect
Happens with Mikrotik ( all version ) and Ubiquiti antenna's client side
Once it happens to a certain client it will continue to happen to the same client ( have enabled watchdog on clients antenna now )
Already submitted a ticket to Mikrotik Ticket#2018072322002421
krunical
Re: Stale PPPoE
Mon Aug 06, 2018 8:27 pm
Hey Heavyd
I have the exact same problem in the exact same way you have described it. im seeing it on CCR 1036ś as well.
Did you find a fix?
Theres no place like 127.0.0.1
BTC: 1BTPtqpfcjEXSpxDi7fgGsfo5et21TTYiq
krunical
Re: Stale PPPoE
Wed Aug 08, 2018 3:46 pm
I have changed the config to have the radio dial (not ideal) as a temp fix for my real problem client while I dig arround for the cause of this issue.
Sent from my CLT-L29 using Tapatalk
IPANetEngineer
Trainer
Trainer
Re: Stale PPPoE
Wed Aug 08, 2018 4:27 pm
What's your CPU load look like?
CHR does a pretty good job of terminating PPPoE...you might consider a design like this for HA and scaling.
http://www.stubarea51.net/2018/04/23/pp ... atorsbras/
Global - MikroTik Support & Consulting - English | Francais | Español | Portuguese +1 855-645-7684
https://iparchitechs.com/services/mikro ... l-support/ mikrotiksupport@iparchitechs.com
krunical
Re: Stale PPPoE
Thu Aug 09, 2018 8:34 am
CPU load at one of the sites is 1%
Other sites varies. Can't see issue on this.
krunical
Re: Stale PPPoE
Mon Aug 13, 2018 10:05 pm
Has anyone else been experiencing this issue?
I still have been unable to pin down the cause.
Users browsing this forum: No registered users and 72 guests
