MUM Europe 2020
fbslim
Attention!!! Routers OS is CRACKED from outside!!!
Thu Jul 26, 2018 9:35 pm
Disabled all denied rules
Arise file mikrotik.php
The same picture on all routers with static IP and winbox port 8291 that looking on hole Internet.
PS
All routers with different versions of firmware. Some of them firmwares are rather old. And same picture on all.
pe1chl
Re: Attention!!! Routers OS is CRACKED from outside!!!
Thu Jul 26, 2018 9:37 pm
We know that already. Thanks for not reading before posting.
See blog.mikrotik.com/security/ for more info.
fbslim
Thu Jul 26, 2018 9:42 pm
TNKS!!!
BartoszP
Thu Jul 26, 2018 9:47 pm
Why is it so hard to ask "uncle Google" for "mikrotik hacked compromised problem winbox 8291" or any combination of these befor posting "CRACKED"?
Real admins use real keyboards.
fbslim
Thu Jul 26, 2018 10:14 pm
Sorry. I sow such hole for the first time...
I have hundreds of routers... And... now i see now way. except... allow only right IPs to manage through 8291, and drop everything else! And disable all other ports.
I was too innocent to belive in "best router" - mikrotik... (
fbslim
Thu Jul 26, 2018 10:16 pm
And everyone HAVE to go such way!!! Wishing to all!!!
There is no BEST anymore...
msatter
Thu Jul 26, 2018 10:25 pm
The blog is just online and had almost no promotion or visibility here.
@fbslim: We have all wishes and Mikrotik is working in all areas to have not horible surprises like this again. Work with us and test the update with different types and hardware revisions before you role it out on a wider scale.
For devices connected to a network/internet it is better to give security a higher priority that features.
Two RB760iGS (hEX S) in series. One does PPPoE and both do IKEv2.
Running:
RouterOS 6.46Beta68 / Winbox 3.20 / MikroTik APP 1.3.7
Having an Android device, use https://github.com/M66B/NetGuard/releases (no root required)
normis
Fri Jul 27, 2018 9:22 am
1. Use Input Firewall on all interfaces: https://wiki.mikrotik.com/wiki/Manual:S ... our_Router
2. Upgrade RouterOS, with button "Check for updates"
3. Change your password after upgrading
Users browsing this forum: No registered users and 89 guests
