prawira
Trainer
Trainer
winbox exploit
Sat Jul 28, 2018 8:20 am
hi everyone,
just found this video on youtube https://youtu.be/h6JSNFhQUN8
and this link regarding the above video https://github.com/BigNerd95/WinboxExploit
questions, will next version of RoS will be able to protect us (as customers) from outsider who use the above tools to mess-up our routers ?
thank you
P
mistry7
Re: winbox exploit
Sat Jul 28, 2018 8:28 am
Fixes for this are avaible for more then a month
vecernik87
Long time Member
Long time Member
Re: winbox exploit
Sat Jul 28, 2018 9:01 am
Firstly, outsider should never have access to your management port. There should be no port 22,23,80,443,8291 opened to other than your computer.
Secondly, this is several months old - it was disclosed on end of April and fix was released within couple of days for both Bugfix and Current release tree. Just couple of weeks ago some kiddo released public script so now, you and many others are panicking because you never cared about security till now. (if you care, you would have proper firewall and you would update your device months ago)
BartoszP
Re: winbox exploit
Sat Jul 28, 2018 1:11 pm
OMG ... next topic about winbox problem ...
@Prawira ... have you checked forum for this problem? Have you tried this http://bfy.tw/J9pW before posting?
Real admins use real keyboards.
mkx
Re: winbox exploit
Sat Jul 28, 2018 2:05 pm
What's worse about @prawira's post is that page, linked as second link in OPs post, has all information about exploit (including fixed version of ROS) as well as basic instructions about how to protect router...
Sigh.
BR,
Metod
vecernik87
Long time Member
Long time Member
Re: winbox exploit
Sat Jul 28, 2018 3:44 pm
Actually, thanks to this script (Earlier I saw different not-that-complete version) I realized that there is hidden caveat to currently recommended "set your firewall" - MAC winbox does ignores the IP firewall (obviously you cant use L3 feature to filter L2 communication). That however means, that even with perfect firewall, people would be vulnerable, if their MAC Winbox is listening on any interface...
Dang.. I am sure several of my devices are incorrectly set up...
Even silly post can bring some good in the end :)
mkx
Re: winbox exploit
Sat Jul 28, 2018 4:44 pm
I guess that MAC Winbox is slightly harder to exploit as attacker would need direct L2 sccess. That's either from ISPs core infrastructure or from your own LAN. Then it all depends on how much you can trust both your ISP and your LAN users.
But then again, it's better to over-protect your boxes.
BR,
Metod
AlainCasault
Trainer
Trainer
Re: winbox exploit
Sat Jul 28, 2018 8:59 pm
That's actually an excellent point. By default, you should NOT trust internal users. If they're honest, then great. Otherwise, plan for the worst.
Sent from Tapatalk
___________________________
Alain Casault, Eng.
If I helped you, let me know!
prawira
Trainer
Trainer
Re: winbox exploit
Thu Aug 02, 2018 10:50 am
dear all,
thank for all of your responses please accept my apologize for the delay.
i do know about the bug-fix upgrade that mention about vulnerability of previous versions, but never see the example of problem before.
honestly, i just see the proof of the mentioned vulnerability couple days ago and get big shock cause of that.
one of you said that i HAVE TO upgrade to the latest version but not for me. as we all know, mikrotik engineers always fix bug A but than bug B come up.
the story is...
+ we got tthe brand new CRS328-24P-4SRM with ROS 6.41 installed since a month ago.
+ we put this new CRS as replacement of our old CRS as this new unit has poe-out features.
+ our installation has vlan tagged on bridges (formally switch) and all of them run fine so far.
+ as soon as this unit upgraded into the last version (6.42.6), all of our vlan tagged does not run.
so it push us to return into the original version
NOTE: this CRS does not allow me to downgrade into 6.40 as the factory version is 6.41
cheers
P
normis
Re: winbox exploit
Thu Aug 02, 2018 10:54 am
Well it's up to you. Be afraid to upgrade because there might be some unknown bug, or risk your network being hacked. Not really a tough choice actually.
prawira
Trainer
Trainer
Re: winbox exploit
Thu Aug 02, 2018 12:11 pm
well...
the function we need are working great on 6.41; has not try on 6.42-6.42.5 yet...
but when we do upgrade to 6.42.6 as the latest current version, the function are broken
P
mrtester
Re: winbox exploit
Thu Aug 02, 2018 12:17 pm
Not sure if this hacker is good or bad. Lets see if on the next step he will upgrade routers or reset their configuration :D
Users browsing this forum: Erriesrhaven, keithy, ljguerci and 102 guests
