dandrzejewski
CAPsMAN Disappeared from WebFig.
Tue Jul 31, 2018 9:48 pm
I installed and enabled the wireless package on an RB850Gx2. The CAPsMAN menu does not appear in webfig on the left, but I can access caps-man in the console. I checked the skin design and it doesn't appear there either. ROS 6.42.6.
dandrzejewski
Re: CAPsMAN Disappeared from WebFig.
Wed Aug 01, 2018 5:17 pm
If you compare the web interface vs winbox, you can see there are a few other things missing, like mpls and openflow.
Web Interface
WinBox Interface
sindy
Wed Aug 01, 2018 6:30 pm
I had a similar issue after upgrade from 40.8 to 41 and the advice I got here and did work was to clear the browser cache.
Instead of writing novels, post /export hide-sensitive. Use find&replace in your favourite text editor to systematically replace all occurrences of each public IP address potentially identifying you by a distinctive pattern such as my.public.ip.1.
dandrzejewski
Wed Aug 01, 2018 7:00 pm
Well I feel silly that I didn't try that first thing. That worked. Thank you.
Users browsing this forum: No registered users and 81 guests
