marko_bg
BUG !!!
Tue Feb 06, 2007 11:20 am
I try this:
on 2.8.16 with this http://wiki.mikrotik.com/wiki/Limiting_ ... of_traffic
work fine, but after, 4000Mb , reading Accounting starting from ZERO (0) , but in OS still are ok number ??!! , 4001 ... 4500 ... 6000 , etc.
in 2.9.38 with SNMP reading, same result, from 0-4000 MB ok, but after 4000mb, reading accouting are start from 0 .. but in simple queue rules in OS, result is ok, 4001 ... 4500 ... 6000 , etc.
Can you fix this ?!
odie
Tue Feb 06, 2007 7:59 pm
there is nothing to repair - is just a counter overflow ...
marko_bg
Tue Feb 06, 2007 11:29 pm
if this is counter overflow ,... why in Queue List number are ok, and there is no error ?
where is overflow , ... in reading method ?
If in Queue List "Downloaded Bytes" have 5647 MiB, how SNMP read only 1600 MiB ?
I have static rules in simple queue for acounting traffic for users and after 4000 MiB , SNMP read from zero?
there is some "bug" or "problems" with this in RouterOS, and this mean that all this method from wiki.mikrotik.com not work propriety after 4000 MiB:
Limiting a user to a given amount of traffic (using firewall)
Limiting a user to a given amount of traffic II (using queues)
Limiting a user to a given amount of traffic with user levels (using queues)
am I right or not ?!
janisk
Wed Feb 07, 2007 10:50 am
http://en.wikipedia.org/wiki/Simple_Net ... t_Protocol
Three simple data types are defined in the SNMPv1 SMI, all of which are unique values:
   1. The integer data type is a signed integer in the range of -2,147,483,648 to 2,147,483,647.
and connection bytes use same signed integer to count bytes in firewall rule.
marko_bg
Wed Feb 07, 2007 11:09 am
ok,
and problems are in signed integer ?
janisk
Wed Feb 07, 2007 11:15 am
problem is in limitations that come in with SNMP
marko_bg
Wed Feb 07, 2007 11:23 am
why in winbox , when open simple queue , I see normal accouting traffic over, 4000 MiB ? this not used signed integer ?
is there any way to reading this data right ?
is this mean , if PPPoE user connect 30 days, and have traffic over 4000MiB, RouterOS send to Radius server , data with error ?
I known this is differet , but where signed integer have influence?
marko_bg
Wed Feb 07, 2007 1:42 pm
ok, you send me mail with this too,
tell me did I folow ...
I can not used any of this :
Limiting a user to a given amount of traffic with user levels (using queues),
also can not used SNMP , ... if my users had traffic over 4000MiB.
and if I want to used , I must reset counter in RouterOS before reach 4000MiB.
Is that you telling me ?
cmit
Wed Feb 07, 2007 1:46 pm
Internal in RouterOS (and what it's showing via the WinBox) obviously the counters are wide enough to cope with that.
That you cannot read those values via SNMP is a limitation of the SNMP protocol or better it's definition of the variable size. There's no way to "repair" this.
If you are using RADIUS for accounting, there will be an issue with byte-counters wrapping around after 4 GB, but there IS an additional RADIUS parameter (search for "gigawords") which is counting, how often the 4 GB limit has been reached. So you CAN do correct ip accounting using RADIUS.
Best regards,
Christian Meis
marko_bg
Wed Feb 07, 2007 2:25 pm
ok , I understand now.
for some reason, I must used snmp, and I will make something to counting 4 GB limit reached.
thanks
janisk
Wed Feb 07, 2007 3:52 pm
you can calculate how much you rclient can download/upload in a hour (like 1GB)
then each hour read value and store it in SQL or where ever you wish to, then with simple SQL you can get how much is used and charge for it.
when you read value do not forget to reset counter for that rule you where reading data.
normis
Re: BUG !!!
Mon Jun 04, 2007 2:42 pm
4Gb limit is fixed in ROSv3
Users browsing this forum: Baidu [Spider], sutrus and 102 guests
