jbird
Bridges getting deleted
Mon Aug 13, 2018 9:59 pm
I've had several routers on which the bridges have gotten deleted somehow. Each time, the router had a bridge with Ethernet and WLAN ports on it. Users would report loss of connectivity, and when I logged into the router, the bridge was gone. The ports showed to be configured for a nonexistent bridge with a name consisting of an asterisk and a number - for example, "*8." The IP address that was assigned to the bridge also gets assigned to bridge *8. Bridge *8 doesn't really exist on the router, but the ports and IP address get assigned to bridge *8. When I create a new bridge and change the bridge interface for each port from *8 to the new bridge, and assign the IP address to the new bridge, users regain connectivity. What would cause bridges to get deleted, and cause ports and IP address reassigned to *8?
jwier92
Re: Bridges getting deleted
Tue Aug 14, 2018 4:22 am
You have applied all updates?
What is the hardware and RouterOS version?
jbird
Sun Aug 19, 2018 6:28 pm
It is 6.42.6.
k6ccc
Sun Aug 19, 2018 7:14 pm
What hardware?
RB750Gr3, RB750r2, CRS326-24G-2S (in SwitchOS), CSS326-24G-2S, CSS106-5G-1S, RB260GS
Not sure if I beat them in submission, or they beat me into submission
Jim
jbird
Thu Aug 23, 2018 10:53 pm
I've seen it on hAP and RB751.
nescafe2002
Long time Member
Long time Member
Thu Aug 23, 2018 11:27 pm
Related topic (yet unresolved): viewtopic.php?f=2&t=138323
Jotne
Thu Aug 23, 2018 11:52 pm
Using new VLAN Bridge ROS >=6.41, you only need one Bridge to solve everything.
Se bottom of my post here:
viewtopic.php?f=2&t=138232
How to use Splunk to monitor your MikroTik Router
MikroTik->Splunk
mducharme
Trainer
Trainer
Fri Aug 24, 2018 12:16 am
Depending on router configuration, I have seen cases where the auto conversion of the bridge does not work properly from pre-6.41. If the bridges disappeared on upgrade from versions below 6.41 then it might be due to this.
Users browsing this forum: No registered users and 92 guests
