virago
I've closed all service ports by mistake
Thu Aug 16, 2018 2:08 pm
As the title said, I've closed all service ports by mistake on my SXTsq Lite5, so I've no longer have access to it to configure it. Is there any way to regain access - maybe throught serial port - in order to not to losse all the configuration by doing a factory reset?
Thanks!
macgaiver
Re: I've closed all service ports by mistake
Thu Aug 16, 2018 3:15 pm
Yes, and there are no way to save config as disabled services are part of configuration.
https://wiki.mikrotik.com/wiki/Manual:Netinstall
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
nescafe2002
Long time Member
Long time Member
Re: I've closed all service ports by mistake  [SOLVED]
Thu Aug 16, 2018 3:20 pm
If you've only disabled the services listed under IP > Services, you should still be able to connect via MAC telnet and MAC winbox.
k6ccc
Thu Aug 16, 2018 3:22 pm
Hopefully you have previously saved backups so after the net install, you can restore from your backup. If not, lesson learned - backup, backup, and off site backup.
Sent from a $&@#% iPhone using Tapatalk
RB750Gr3, RB750r2, CRS326-24G-2S (in SwitchOS), CSS326-24G-2S, CSS106-5G-1S, RB260GS
Not sure if I beat them in submission, or they beat me into submission
Jim
virago
Thu Aug 16, 2018 11:34 pm
This!
Thank you! You save my day! :D
Users browsing this forum: No registered users and 26 guests
