chriscolden
RB3011 Switch VLAN Access Port Issue
Wed Aug 22, 2018 5:51 pm
I have an RB3011 with VLANs on the Switch Chips. I use trunk ports and access ports. The issue I have is with the access ports. When I torch the port, I see some traffic has a vlan tag and other traffic doesn't. All coming from the same client.
Is this a bug, or have I incorrectly configured the access ports?
set 1 vlan-mode=secure
set 2 default-vlan-id=10 vlan-header=always-strip vlan-mode=secure
set 3 default-vlan-id=20 vlan-header=always-strip vlan-mode=secure
set 4 default-vlan-id=30 vlan-header=always-strip vlan-mode=secure
set 5 default-vlan-id=20 vlan-header=always-strip vlan-mode=secure
set 6 default-vlan-id=20 vlan-header=always-strip vlan-mode=secure
set 7 default-vlan-id=20 vlan-header=always-strip vlan-mode=secure
set 8 default-vlan-id=20 vlan-header=always-strip vlan-mode=secure
set 9 vlan-mode=secure
set 10 vlan-mode=secure
set 11 vlan-mode=secure
add independent-learning=no ports=switch1-cpu,ether2-uplink,ether5 switch=switch1 vlan-id=30
add independent-learning=no ports=switch2-cpu,ether10 switch=switch2 vlan-id=30
add independent-learning=no ports=switch1-cpu,ether3,ether2-uplink switch=switch1 vlan-id=10
add independent-learning=no ports=switch2-cpu,ether10 switch=switch2 vlan-id=10
add independent-learning=no ports=switch1-cpu,ether2-uplink,ether4 switch=switch1 vlan-id=20
add independent-learning=no ports=switch2-cpu,ether6,ether7,ether8,ether9,ether10 switch=switch2 vlan-id=20
add independent-learning=no ports=switch2-cpu,ether10 switch=switch2 vlan-id=666
Traffic without the VLAN tag is being dropped by the firewall as its being seen as on the bridge interface, not the vlan interface.
I'm running 6.42.7
Chris
alexvdbaan
Trainer
Trainer
Re: RB3011 Switch VLAN Access Port Issue
Fri Aug 24, 2018 8:38 pm
Chris,
You mention bridge but you don't show your /interface export. Could you please add a full export?
Thanks, Alex
611
Wed Oct 17, 2018 11:08 am
Looks like I have the same or related issue with RB3011: some packets are seemingly coming untagged from an access port, this results in input from the master bridge instead of configured VLAN.
I have switch and interface setup as described in https://wiki.mikrotik.com/wiki/Manual:B ... witch_chip.
ISP is connected to ether2, all internal clients on access switch connected to ether10.
The issue is not observed if ISP is connected thru an access switch on trunk port (ether1).
The config (related part) is:
add name=bridge-master protocol-mode=none
add bridge=bridge-master interface=ether1
add bridge=bridge-master interface=ether10
add bridge=bridge-master interface=ether2
add bridge=bridge-master interface=ether3
add bridge=bridge-master interface=ether4
add bridge=bridge-master interface=ether5
add bridge=bridge-master interface=ether6
add bridge=bridge-master interface=ether7
add bridge=bridge-master interface=ether8
add bridge=bridge-master interface=ether9
/interface vlan
add interface=bridge-master loop-protect=off name=vlan-isp vlan-id=10
add interface=bridge-master name=vlan-private vlan-id=20
set 0 vlan-header=add-if-missing vlan-mode=secure
set 1 default-vlan-id=10 vlan-header=always-strip vlan-mode=secure
set 2 default-vlan-id=20 vlan-header=always-strip vlan-mode=secure
set 4 vlan-header=add-if-missing vlan-mode=secure
set 9 vlan-header=add-if-missing vlan-mode=secure
set 10 vlan-header=add-if-missing vlan-mode=secure
set 11 vlan-header=add-if-missing vlan-mode=secure
add independent-learning=yes ports=switch1-cpu,ether1,ether2 switch=switch1 \
    vlan-id=10
add independent-learning=yes ports=\
    switch1-cpu,ether1,ether3,ether4,ether5 switch=switch1 vlan-id=20
add address=<internal IP>/24 interface=vlan-private network=<internal net>
add address=<external IP>/24 interface=vlan-isp network=<ISP net>
add action=drop chain=input comment="master bridge leakage" in-interface=\
    bridge-master log=yes
HW offload is on all ports:
 #     INTERFACE     BRIDGE        HW  PVID PR  PATH-COST INTERNA...    HORIZON
 0 I H ether1        bridge-master yes    1 0x         10         10       none
 1   H ether10       bridge-master yes    1 0x         10         10       none
 2   H ether2        bridge-master yes    1 0x         10         10       none
 3 I H ether3        bridge-master yes    1 0x         10         10       none
 4 I H ether4        bridge-master yes    1 0x         10         10       none
 5 I H ether5        bridge-master yes    1 0x         10         10       none
 6 I H ether6        bridge-master yes    1 0x         10         10       none
 7 I H ether7        bridge-master yes    1 0x         10         10       none
 8 I H ether8        bridge-master yes    1 0x         10         10       none
 9 I H ether9        bridge-master yes    1 0x         10         10       none
All packets from ISP should go to vlan-isp (and there's no IP addresses on master bridge), still some packets are seeping through:
08:31:22 firewall,info input: in:bridge-master out:(unknown 0), src-mac <ISP gw MAC>, proto TCP (SYN), 79.167.15.240:13670-><my ext IP>:88, len 40
09:07:12 firewall,info input: in:bridge-master out:(unknown 0), src-mac <ISP gw MAC>, proto TCP (SYN), 221.213.237.97:25555-><my ext IP>:23, len 40
09:15:16 firewall,info input: in:bridge-master out:(unknown 0), src-mac <ISP gw MAC>, proto TCP (RST), 13.33.241.79:443-><my ext IP>:52236, len 40
09:28:24 firewall,info input: in:bridge-master out:(unknown 0), src-mac <ISP gw MAC>, proto TCP (ACK), 66.211.182.222:443-><my ext IP>:4782, len 52
10:03:16 firewall,info input: in:bridge-master out:(unknown 0), src-mac <ISP gw MAC>, proto TCP (RST), 173.194.73.99:443-><my ext IP>:53142, len 40
611
Thu Oct 18, 2018 9:27 am
I've done some further testing - modified firewall rules to catch all packets fallen off the VLAN to the master bridge.
Total seepage is about 0.1% of all packets.
The good news - I've been unable to reproduce the issue in a controlled environment like this:
The testbed:
[MT, 10.50.0.2>] <-Ether-> [<VLAN 50 access port <10.50.0.1 on VLAN interface - Device being tested - 10.60.0.1 on VLAN interface> VLAN 60 access port>] <-Ether-> [MT, 10.60.0.2>]
BTest between 10.50.0.2 and 10.60.0.2 as a test load.
Config of the device being tested (relevant part):
/interface vlan
add interface=bridge-master name=vlan-50 vlan-id=50
add interface=bridge-master name=vlan-60 vlan-id=60
set 0 default-vlan-id=50 vlan-header=always-strip vlan-mode=secure
set 4 default-vlan-id=60 vlan-header=always-strip vlan-mode=secure
add independent-learning=yes ports=switch1-cpu,ether1 switch=switch1 vlan-id=\
    50
add independent-learning=yes ports=switch1-cpu,ether5 switch=switch1 vlan-id=\
    60
add address=10.50.0.1/24 interface=vlan-50 network=10.50.0.0
add address=10.60.0.1/24 interface=vlan-60 network=10.60.0.0
(The config is for hAP ac (switch1-cpu is port 4) - I've tried it first as I have a spare one, and it has the same switch chip.)
6.43.2 on all devices.
On this testbed config I see zero packet seepage.
I've tried this config of the same switch of the same RB3011 that seeps ISP packets. Zero packet seepage.
Seepage from real-world VLAN seems unaffected - no noticeable change in rate when the test is running.
So it must be some specifics in some packets coming from ISP, that causing VLAN to seep packets.
I'll dig deeper (try to add another device between ISP and RB3011, capture the packets and look closer at offending ones) and get back.
chriscolden
Fri Mar 01, 2019 6:19 pm
Sorry for the late reply.
The issue is with the switch not the bridge. I've spoken with mikrotik support regarding this and they have been able to reproduce the issue.
Confirmed it will be passed onto the devs but no idea when it will be fix.
Chris
anav
Fri Mar 01, 2019 9:23 pm
A good reason to stick with VLANS on a single bridge approach. Slower but no leakage or errors is better. Tortoise wins the race!!!
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
Users browsing this forum: Zacharias and 70 guests
