Per subject line. ROS v6.15 - 6.35.4 works fine with Jetpack 7730 tethered via USB, v6.36+ fails to assign LTE interface but Jetpack is seen correctly in Resources>>USB. Also tried 6.43rc64.
Another user has the same problem:
viewtopic.php?f=3&t=136324&p=671482&hil ... 30#p671482
I would be fine running 6.35 to regain this functionality, but the new RB 951 I bought to replace a 750 damaged by a nearby lightning strike won't accept a downgrade to that version as it came pre-loaded with 6.40.8.
This could be easy to fix - just take a look at the (lte) changes you made in 6.36 vs. 6.35.
Hoping for a solution. I now no longer have backup hardware for this particular site at which LTE is the only option for a small wired/wireless office network.
