MUM Europe 2020
jober
Long time Member
Long time Member
NetBios traffic over a VPN
Sun Feb 11, 2007 10:36 pm
I am tring to setup a pptp server on my MT that can pass netbios traffic to the 8 people connected to the pptp server. I want all of the PCs to see each other. I have two PC on the LAN side and 6 on the WAN side.
Can anyone tell me how to make this work?
tneumann
Sun Feb 11, 2007 11:19 pm
As long as it is NetBIOS over IP (and not NetBEUI, which can't be routed) then it is just IP traffic like any other IP packets, so you do not need to do anything special with your VPN to make this work.
If you're talking about what can be 'seen' in Windows Network Neighborhood then that's a different issue and more of a windows problem than a routing or a MikroTik problem (i.e. WINS or DNS versus broadcast-based NetBIOS name discovery based on elected 'master browsers' and other MS suckage that I would rather not concern myself with...)
--Tom
jober
Long time Member
Long time Member
Mon Mar 05, 2007 11:23 pm
OK, I want to see the files and printers on the other network when I browse Network Neighborhood from ether side of the VPN.
They don't have a WINS server and I don't want to use EoIP(if EoIP would work). But If EoIP is the only way I guess I could make them buy a RB133.
Anyway, this whole thing suchs because Linksys End point VPN routers do it but MT is looking like it's not going to work.
bjohns
Tue Mar 06, 2007 12:04 am
Setting up a WINS server isn't that difficult - if there's a windows server then its just turning it on. Otherwise Samba is excellent. This would be my suggestion for a client/server style VPN.
Interesting the Linksys ones do this - I might investigate them further and see what kind of magic it is.
tneumann
Tue Mar 06, 2007 12:35 am
Usually UDP broadcast forwarding, think DHCP relay with a different destination port (137 instead of 67).
Anyway, I agree that a WINS server is a much cleaner solution.
And while we are at it, the following link is worth reading:
http://www.microsoft.com/technet/networ ... _ch11.mspx
--Tom
jo2jo
Forum Veteran
Forum Veteran
Tue Mar 06, 2007 12:53 am
any ideas as to how to implemment this on MT? ( UDP broadcast forwarding) I ask as i have a few locations that use VPN for windows file and print services..and i just hard code the LMhosts files on the clients...
a constantly updated system would be real nice..
tks
:beep :beep :beep
jober
Long time Member
Long time Member
Tue Mar 06, 2007 1:18 am
So if I used an EoIP tunnel what would stop the two networks DHCP servers from muching up.
Oh, And I would go with a WINS server but the customer has just layed out a lot of cast on new PCs so a server is a at least a year away.
On another Note, I use a VPN client called Hamachi to do VPN LAN games, so I know this would work if I bridge the PCs running Hamachi on each side to the ethernet cards and then add the routes in the routers. BUT, I don't like using a Free program that may not be free in the future.
bjohns
Tue Mar 06, 2007 1:31 am
Sounds like something you can mimic using RouterOS, if not then maybe MT would like to include something like this?
jober
Long time Member
Long time Member
Tue Mar 06, 2007 2:19 am
The Linksys routers have the option of: "Enable NetBIOS Broadcast"
All you have top do it check the little box and you then see all the shared folders and printers.
If someone has an easy way to do this it would be a good sticky or wiki.
bjohns
Tue Mar 06, 2007 2:37 am
From the site linked by tneumann:
You can enable NetBT broadcast forwarding (UDP ports 137 and 138) on some routers. However, the practice of enabling NetBT broadcast forwarding to simplify NetBIOS name resolution is highly discouraged.
So I would lean towards WINS.
jo2jo
Forum Veteran
Forum Veteran
Mon Mar 12, 2007 10:08 am
I think the issue is WINS requires windows server and a seperate machine, and for many 5-15 computer offices, or homes, that want secure remote access to their files, setting up a wins server is not possible.
am i mistaken about the need for a server os, and a seperate server?
tks
:beep :beep :beep
andrewluck
Forum Veteran
Forum Veteran
Mon Mar 12, 2007 2:03 pm
SAMBA will also act as a WINS server.
Regards
Andrew
Users browsing this forum: Bing [Bot], Google [Bot], unknownGuy and 126 guests
