MUM Europe 2020
Black2vs2
Really simple question about RB3011UiAS-RM
Mon Sep 17, 2018 10:25 am
I'm sorry for the noob questione bit it's Not specified on the site. Does this model have wireless ap?
Thanks in advance,
- Black
normis
Re: Really simple question about RB3011UiAS-RM
Mon Sep 17, 2018 10:29 am
No it does not. There are other devices with wireless.
Black2vs2
Mon Sep 17, 2018 10:39 am
Thanks for the fast answer!
I was thinking about buying a router with 10 1Gigabit ports and a wireless system in it. Any advice?
whitbread
Mon Sep 17, 2018 12:39 pm
Best advice is to buy two devices. Always use seperate ap and router/switch.
nescafe2002
Long time Member
Long time Member
Mon Sep 17, 2018 12:55 pm
Black2vs2
Mon Sep 17, 2018 6:07 pm
Thank you all for the answers! Really appreciate it
Paternot
Long time Member
Long time Member
Mon Sep 17, 2018 7:06 pm
Before You jump the gun, take a look at the block diagram.
The 4011, for example. It does have 10 Gb ports - but they are spread in two switches - and each switch has a 2,5Gb link with the CPU.
This can be ok - or not - for Your use case. Best advice is: buy a router and a switch. Each device will do only one thing - and will do it well.
Users browsing this forum: No registered users and 111 guests
