ithierack
Wrong "Last Link Down Time" in Winbox
Tue Sep 18, 2018 11:46 am
did not know exactly when this happens. But in WinBox, the "Last Link Down Time" is displayed wrong. It is correct displayed in the Web-Interface.
It display some time in the future, it looks like starttime of WinBox + 30 hours. Uptime itself is correct.
See screenshot.
Does anyone else see this? Would be nice to get the correct value here, so i don't need to grep the info out of the logfiles if i need this.
Router is an CCR1009-8g-1S-1S+ with latest 6.43. But i saw this also in latest 6.42.
DummyPLUG
Re: Wrong "Last Link Down Time" in Winbox
Sun Sep 23, 2018 2:52 pm
Happen to my CCr1009-7G too, everywhere is correct except in winbox, beside link down time the "last link up time" will sometime display the current time instead of the correct one
doukas
Wed Sep 26, 2018 4:04 pm
Happen to my CCr1009-7G too, everywhere is correct except in winbox, beside link down time the "last link up time" will sometime display the current time instead of the correct one[/u]
The same problem in my RB3011UiAS after upgrade to v6.43. Any solution??
Thanks in advance!
stoser
Thu Sep 27, 2018 6:59 pm
I am also having this problem, on RouterBOARD 3011UiAS, running 6.40.9, Firmware 3.41 However I do not believe that this has to do with upgrade version or firmware. I believe that it is the newer versions of winbox.
Winbox 3.11 connected to the same router shows CORRECT dates in "last link up time" and "last link down time"
Winbox 3.17 shows incorrect dates, specifically about 18 hours in the future.
Winbox 3.18 shows incorrect dates as well.
stoser
Fri Sep 28, 2018 2:45 pm
I can confirm that this occurs on the following routers using Winbox 3.17 AND Winbox 3.18.
Note: The strange date behavior is NOT occurring with winbox 3.11, on the versions that it can connect to (pre 6.43).
Power Box Pro (960PGS) running 6.42.7
750UP running 6.42.7
Power Box 750P r2 running 6.43
951-2n running 6.43
2011UiAS-2HnD running 6.43 -- This one is weird. The last link uptime of all active interfaces seems always gets set to the time that winbox connected ...
The incorrect dates appear to be random. Each time winbox connects, they may or may not change to dates ranging from a few hours to a few weeks in the future ... That it to say, one cannot simply calculate the true date.
Kind regards, --
stoser
Tue Oct 30, 2018 4:16 am
Bump...
Yesterday I got around to upgrading all of the RBs in my previous post to 6.43.4, and a CRS 326 as well, both firmware and packages. Using both winbox 3.17 and 3.18, the "Last Link uptime" of all active interfaces always gets set to the time that winbox connected ... The last link downtime is always blank.
Six different models of RB, and a CRS, all with the same problem. Does anyone know if the next version of Winbox will address this issue? Does anyone know if there is a workaround?
odge
Sat Nov 10, 2018 10:35 am
Hi
On Ticket#2018110622004024 I got :
Problem is now reported to our development team.
When it will be fixed, then detailed problem description (fix) will be mentioned in RouterOS and/or Winbox changelog.
stoser
Sun Nov 11, 2018 4:55 pm
I reported it as well
Ticket#2018103022005561
Mikrotik support asked me for screenshots and additional details, I gave them screenshots from 3 differnt RBs, and using different versions of Winbox (when possible). Hopefully it will be corrected in the next version of Winbox.
Treath1
Mon Nov 12, 2018 4:54 pm
I am also having this issue with my routers.
I have a CCR1009-8G-1S-1S+ 6.43.2
So strange the dates showing in last link down and uptime are seemingly random. For instance the one I am looking at now is 1 month 5 days ahead.
I checked the system clock on both routers, both are "correct" as in the date and time are accurate, but the interface details are completely wrong.
jspool
Fri Nov 30, 2018 5:51 am
I also notice this on some of my VPN clients. Many show "Last Link Up Time" over a month in the future.
fuzzbawl
Wed Jan 09, 2019 9:02 pm
I was able to resolve this on our workstations, it seems to be a difference in how Winbox is writing session files. If you delete the "%userprofile%\appdata\roaming\mikrotik\winbox\sessions" directory, then it all works fine again and correct link down dates are shown. We've confirmed that on two different computers and so far, so good!
CZFan
Sat Jan 12, 2019 9:17 pm
Thank you, will try this next time
MTCNA, MTCTCE, MTCRE & MTCINE
stoser
Sun Jan 13, 2019 5:42 pm
I confirm that this works, but only for the first time that winbox is used after the session files are deleted. Once the session data is rewritten by winbox, the next time winbox is opened for that RB, the same problem appears. This may be useful information for the Mikrotik developers, but it's not a usefull workaraound, especially since the session data contains all of the winbox column formatting that I am sure we all painstakingly work on ... I would rather use the terminal to see one erroneous data point, that to lose all of my other winbox formatting ...
rzirzi
Sun Feb 17, 2019 11:35 pm
I can confirm that too. The same problem, and deleting sessions files works ONLY for the first time. Next login with Winbox - shows the wrong "Last Link Down Time" - there is a logon date and time!
MikroTik team - please repair that problem.
Cha0s
Mon Feb 18, 2019 12:05 am
I confirm the problem.
mongobongo
Fri Mar 29, 2019 3:13 pm
Same here!
RouterOS: 6.44.1
WinBox: 3.17
paulct
Fri Mar 29, 2019 4:30 pm
same here, a real issue when you to need to prove something.
AlexAfanasyev
Thu May 02, 2019 6:24 pm
1y passed. Problem still not resolved :(
RB3011UiAS
ROS 6.44.3 (latest "stable")
dbai
Wed Apr 15, 2020 10:39 am
Problem persists.
CCR1036-12G-4S
ROS v6,46,5
WinBox v3.22 (64bit)
urnash
Fri Apr 17, 2020 2:20 pm
Проблема до сих пор не решена!!!
The problem is still not resolved !!!
Есть обходной путь решения проблемы, надо переименовать папку сессии, зайти в винбокс и авторизоваться на роутере, закрыть винбокс, удалить новую созданную папку сессии, старую переименовать обратно.
Теперь все работает, но не знаю на сколько долго...
maxsaf
Tue Jun 23, 2020 7:08 pm
Присоединяюсь к вопросу, имею ту же проблему
I have the same issue
anishpsla
Sat Jun 27, 2020 9:26 pm
Problem still persist. Please clear it as soon as possible.
stoser
Wed Aug 05, 2020 2:23 pm
In the change log for Version 6.47 (2020-Jun-02 07:38) it states:
*) winbox - fixed dates and times in interface link up/down properties (WinBox v3.24 required);
So ... Supposedly this should be fixed. I have not tested yet because I only use "long term" versions in production routers, whereas 6.47.1 is still only a "stable" version.. But if anyone has time to test this out, please post if the problem was fixed. Kind regards -
doukas
Wed Nov 18, 2020 9:59 pm
upgrade winbox to v3.27 and the problem solved !!!
stoser
Wed Nov 18, 2020 11:48 pm
@doukas, what FW version are you using?
Users browsing this forum: marcin21 and 147 guests
