If you have an ISP that gives you more than one IP using DHCP you would like to use them all.
The VRRP solution mention here viewtopic.php?f=2&t=93517&p=687533#p466594 I was not able to get to work.
My solution is some dirty, and your ISP may auto block the port since he sees multiple mac on same port.
What I have done is to use a MT with many ports, eks CRS125.
On this device I make a group of port that will be the outside port.
One port connects from this group to ISP, the other ports connects back to other bridges in your switch.
I was not able to get it to work with the new VLAN aware Bridge solution, so I do get one Bridge for each IP.
For every extra IP you like to get, you need two extra ports on the router.
You need three Ethernet cable extra.
Connect port #2 to #10
Connect port #3 to #11
Connect port #4 to #12
The inside design is not describe here, but should be easy to setup.
Here is the design: And the resulting DHCP information:
And the configuration:
Code: Select all
# sep/20/2018 07:51:52 by RouterOS 6.43.1
# model = CRS125-24G-1S-2HnD
add fast-forward=no name=Bridge_Outside
add fast-forward=no name=Bridge_P10
add fast-forward=no name=Bridge_P11
add fast-forward=no name=Bridge_P12
add bridge=Bridge_Outside interface=ether1
add bridge=Bridge_Outside interface=ether2
add bridge=Bridge_Outside interface=ether3
add bridge=Bridge_Outside interface=ether4
add bridge=Bridge_P10 interface=ether10
add bridge=Bridge_P11 interface=ether11
add bridge=Bridge_P12 interface=ether12
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=Bridge_P10
add dhcp-options=hostname,clientid disabled=no interface=Bridge_P11
add dhcp-options=hostname,clientid disabled=no interface=Bridge_P12
It seems that you can even set on DHCP client on the Bridge_Outside to get 4 IP with this solution.
