MUM Europe 2020
Joni
Default config exports
Fri Oct 05, 2018 11:29 am
In the spirit of this, having to downgrade, export, upgrade, etc...
I've found a different factory reset behavior after upgrading to v6.42.9. In v6.40.9 the interfaces, DHCP server, and firewall policies were included by default. Now in v6.42.9, only a static IP address of 192.168.88.1 is configured on Interface 1, without a DHCP server, or firewall policies (which leaves the router insecure and vulnerable to hacking when connected to the internet). Why was this changed?
The above has always been the default on the more enterprise-oriented CCR routers, the detailed config that you describe was always only on the smaller home-oriented routers.
Just tested on RB750Gr3, 6.42.9 default configuration script just sets IP on ether1. Version 6.42.7 have full default configuration, fw, dhcp, bridge etc.
We should really export all default configs here, for general review and comparison... https://wiki.mikrotik.com/wiki/Manual:D ... igurations
So executing "/system default-configuration print" on a "RBSXTR&R11e-LTE" (ie international SXT LTE kit) running v6.41.3 (factory default) which is lost when upgrading to v6.42.9 (long-term, bugfix)
            script: #| CPE RouterMode:
                    #|  * wireless interface connected to providers network (WAN port);
                    #|  * WAN port is protected by firewall and enabled DHCP client
                    #| LAN Configuration:
                    #|     IP address 192.168.88.1/24 is set on bridge (LAN port)
                    #|     DHCP Server: enabled;
                    #|     DNS: enabled;
                    #| WAN (gateway) Configuration:
                    #|     gateway:  lte1 ;
                    #|     ip4 firewall:  enabled;
                    #|     NAT:   enabled;
                    :log info Starting_defconf_script_;
                    # Apply configuration.
                    # these commands are executed after installation or configuration reset
                    :if ($action = "apply") do={
                    # wait for interfaces
                    :local count 0;
                    :while ([/interface ethernet find] = "") do={
                    :if ($count = 30) do={
                    :log warning "DefConf: Unable to find ethernet interfaces";
                    /quit;
                    :delay 1s; :set count ($count +1);
                      :local count 0;
                      :while ([/interface lte find] = "") do={
                        :if ($count = 40) do={
                          :log warning "DefConf: Unable to find LTE interface(s)";
                          /ip address add address=192.168.88.1/24 interface=ether1 comment="defconf";
                          /quit
                        :delay 1s;
                     /interface list add name=WAN comment="defconf"
                     /interface list add name=LAN comment="defconf"
                       add name=bridge disabled=no auto-mac=yes protocol-mode=rstp comment=defconf;
                     :local bMACIsSet 0;
                     :foreach k in=[/interface find where !(slave=yes  || name~"lte1" || name~"bridge")] do={
                       :local tmpPortName [/interface get $k name];
                       :log info "port: $tmpPortName"
                       :if ($bMACIsSet = 0) do={
                         :if ([/interface get $k type] = "ether") do={
                           /interface bridge set "bridge" auto-mac=no admin-mac=[/interface ethernet get $tmpPortName mac-address];
                           :set bMACIsSet 1;
                         add bridge=bridge interface=$tmpPortName comment=defconf;
                       /ip pool add name="default-dhcp" ranges=192.168.88.10-192.168.88.254;
                         add name=defconf address-pool="default-dhcp" interface=bridge lease-time=10m disabled=no;
                         add address=192.168.88.0/24 gateway=192.168.88.1 comment="defconf";
                      /ip address add address=192.168.88.1/24 interface=bridge comment="defconf";
                     /ip dns {
                         set allow-remote-requests=yes
                         static add name=router.lan address=192.168.88.1
                     /interface list member add list=LAN interface=bridge comment="defconf"
                     /interface list member add list=WAN interface=lte1 comment="defconf"
                     /ip firewall nat add chain=srcnat out-interface-list=WAN ipsec-policy=out,none action=masquerade comment="defconf: masquerade"
                     /ip firewall {
                       filter add chain=input action=accept connection-state=established,related,untracked comment="defconf: accept established,related,untracked"
                       filter add chain=input action=drop connection-state=invalid comment="defconf: drop invalid"
                       filter add chain=input action=accept protocol=icmp comment="defconf: accept ICMP"
                       filter add chain=input action=drop in-interface-list=!LAN comment="defconf: drop all not coming from LAN"
                       filter add chain=forward action=accept ipsec-policy=in,ipsec comment="defconf: accept in ipsec policy"
                       filter add chain=forward action=accept ipsec-policy=out,ipsec comment="defconf: accept out ipsec policy"
                       filter add chain=forward action=fasttrack-connection connection-state=established,related comment="defconf: fasttrack"
                       filter add chain=forward action=accept connection-state=established,related,untracked comment="defconf: accept established,related, untracked"
                       filter add chain=forward action=drop connection-state=invalid comment="defconf: drop invalid"
                       filter add chain=forward action=drop connection-state=new connection-nat-state=!dstnat in-interface-list=WAN comment="defconf:  drop all from WAN not DSTNATed"
                       /ip neighbor discovery-settings set discover-interface-list=LAN
                       /tool mac-server set allowed-interface-list=LAN
                       /tool mac-server mac-winbox set allowed-interface-list=LAN
                    # Revert configuration.
                    # these commands are executed if user requests to remove default configuration
                    :if ($action = "revert") do={
                    /user set admin password=""
                     /system routerboard mode-button set enabled=no
                     /system routerboard mode-button set on-event=""
                     /system script remove [find comment~"defconf"]
                     /ip firewall filter remove [find comment~"defconf"]
                     /ip firewall nat remove [find comment~"defconf"]
                     /interface list member remove [find comment~"defconf"]
                     /interface detect-internet set detect-interface-list=none
                     /interface detect-internet set lan-interface-list=none
                     /interface detect-internet set wan-interface-list=none
                     /interface detect-internet set internet-interface-list=none
                     /interface list remove [find comment~"defconf"]
                     /tool mac-server set allowed-interface-list=all
                     /tool mac-server mac-winbox set allowed-interface-list=all
                     /ip neighbor discovery-settings set discover-interface-list=!dynamic
                       :local o [/ip dhcp-server network find comment="defconf"]
                       :if ([:len $o] != 0) do={ /ip dhcp-server network remove $o }
                       :local o [/ip dhcp-server find name="defconf" !disabled]
                       :if ([:len $o] != 0) do={ /ip dhcp-server remove $o }
                       /ip pool {
                         :local o [find name="default-dhcp" ranges=192.168.88.10-192.168.88.254]
                         :if ([:len $o] != 0) do={ remove $o }
                       :local o [/ip dhcp-client find comment="defconf"]
                       :if ([:len $o] != 0) do={ /ip dhcp-client remove $o }
                     /ip dns {
                       set allow-remote-requests=no
                       :local o [static find name=router.lan address=192.168.88.1]
                       :if ([:len $o] != 0) do={ static remove $o }
                     /ip address {
                       :local o [find comment="defconf"]
                     :foreach iface in=[/interface ethernet find] do={
                       /interface ethernet set $iface name=[get $iface default-name]
                     /interface bridge port remove [find comment="defconf"]
                     /interface bridge remove [find comment="defconf"]
                    :log info Defconf_script_finished;
and
 caps-mode-script:  #-------------------------------------------------------------------------------
                    # Note: script will not execute at all (will throw a syntax error) if
                    #       dhcp or wireless-fp packages are not installed
                    #| CAP configuration
                    #|   Wireless interfaces are set to be managed by CAPsMAN.
                    #|   All ethernet interfaces and CAPsMAN managed interfaces are bridged.
                    #|   DHCP client is set on bridge interface.
                    # bridge port name
                    :global brName  "bridgeLocal";
                    :global logPref "defconf:";
                    :global action;
                    :log info $action
                      # wait for ethernet interfaces
                      :local count 0;
                          /quit;
                        :delay 1s; :set count ($count + 1);
                      :local macSet 0;
                      :local tmpMac "";
                      :foreach k in=[/interface ethernet find] do={
                        # first ethernet is found; add bridge and set mac address of the ethernet port
                        :if ($macSet = 0) do={
                          :set tmpMac [/interface ethernet get $k mac-address];
                          /interface bridge add name=$brName auto-mac=no admin-mac=$tmpMac comment="defconf";
                          :set macSet 1;
                        # add bridge ports
                        /interface bridge port add bridge=$brName interface=$k comment="defconf"
                      # try to add dhcp client on bridge interface (may fail if already exist)
                      :do {
                        /ip dhcp-client add interface=$brName disabled=no comment="defconf"
                      } on-error={ :log warning "$logPref unable to add dhcp client";}
                      # try to configure caps (may fail if for example specified interfaces are missing)
                      :local interfacesList "";
                      :local bFirst 1;
                      # wait for wireless interfaces
                      :while ([/interface wireless find] = "") do={
                          :log warning "DefConf: Unable to find wireless interfaces";
                          /quit;
                      # delay just to make sure that all wireless interfaces are loaded
                      :delay 5s;
                      :foreach i in=[/interface wireless find] do={
                        if ($bFirst = 1) do={
                          :set interfacesList [/interface wireless get $i name];
                          :set bFirst 0;
                        } else={
                          :set interfacesList "$interfacesList,$[/interface wireless get $i name]";
                      :do {
                        /interface wireless cap
                          set enabled=yes interfaces=$interfacesList discovery-interfaces=$brName bridge=$brName
                      } on-error={ :log warning "$logPref unable to configure caps";}
                      :do {
                          set enabled=no interfaces="" discovery-interfaces="" bridge=none
                      } on-error={ :log warning "$logPref unable to unset caps";}
just a thought... as the difference, among other things is 53 rows of firewall rules vs 0
Joni
Re: Default config exports
Wed Oct 31, 2018 9:20 am
So executing "/system default-configuration print" on a "RB962UiGS-5HacT2HnT" (ie international hAP ac) running v6.42.7 (factory default) which is lost when upgrading to v6.42.9 (long-term, bugfix):
            script: :global ssid;
                    #| RouterMode:
                    #|  * Wireless and Ethernet interfaces (except WAN port ether1)
                    #|    are part of LAN bridge
                    #| wlan1 Configuration:
                    #|     mode:          ap-bridge;
                    #|     band:          2ghz-b/g/n;
                    #|     ht-chains:     0,1,2;
                    #|     ht-extension:  20/40mhz-Ce;
                    #| wlan2 Configuration:
                    #|     mode:          ap-bridge;
                    #|     band:          5ghz-a/n/ac;
                    #|     ht-extension:  20/40/80mhz-Ceee;
                    #|     gateway:  ether1 ;
                    #|     ip6 firewall:  enabled;
                    #|     NAT:   enabled;
                    #|     DHCP Client: enabled;
                    #|     DNS: enabled;
                    :local count 0;
                    /quit;
                      :local count 0;
                      :while ([/interface wireless print count-only] < 2) do={
                          :log warning "DefConf: Unable to find wireless interface(s)";
                          /quit
                        :delay 1s;
                      /interface wireless {
                        set wlan1 mode=ap-bridge band=2ghz-b/g/n tx-chains=0,1,2 rx-chains=0,1,2 \
                          disabled=no wireless-protocol=802.11 distance=indoors
                        :local wlanMac  [/interface wireless get wlan1 mac-address];
                        :set ssid "MikroTik-$[:pick $wlanMac 9 11]$[:pick $wlanMac 12 14]$[:pick $wlanMac 15 17]"
                        set wlan1 ssid=$ssid
                        set wlan1 frequency=auto
                        set wlan1 channel-width=20/40mhz-Ce ;
                        set wlan2 mode=ap-bridge band=5ghz-a/n/ac tx-chains=0,1,2 rx-chains=0,1,2 \
                        :local wlanMac  [/interface wireless get wlan2 mac-address];
                        set wlan2 ssid=$ssid
                        set wlan2 frequency=auto
                        set wlan2 channel-width=20/40/80mhz-Ceee ;
                     :local bMACIsSet 0;
                     :foreach k in=[/interface find where !(slave=yes  || name="ether1" || name~"bridge")] do={
                           :set bMACIsSet 1;
                       /ip dhcp-client add interface=ether1 disabled=no comment="defconf";
                     /interface list member add list=WAN interface=ether1 comment="defconf"
                     /ip firewall {
                     /ipv6 firewall {
                       address-list add list=bad_ipv6 address=::/128 comment="defconf: unspecified address"
                       address-list add list=bad_ipv6 address=::1 comment="defconf: lo"
                       address-list add list=bad_ipv6 address=fec0::/10 comment="defconf: site-local"
                       address-list add list=bad_ipv6 address=::ffff:0:0/96 comment="defconf: ipv4-mapped"
                       address-list add list=bad_ipv6 address=::/96 comment="defconf: ipv4 compat"
                       address-list add list=bad_ipv6 address=100::/64 comment="defconf: discard only "
                       address-list add list=bad_ipv6 address=2001:db8::/32 comment="defconf: documentation"
                       address-list add list=bad_ipv6 address=2001:10::/28 comment="defconf: ORCHID"
                       address-list add list=bad_ipv6 address=3ffe::/16 comment="defconf: 6bone"
                       address-list add list=bad_ipv6 address=::224.0.0.0/100 comment="defconf: other"
                       address-list add list=bad_ipv6 address=::127.0.0.0/104 comment="defconf: other"
                       address-list add list=bad_ipv6 address=::/104 comment="defconf: other"
                       address-list add list=bad_ipv6 address=::255.0.0.0/104 comment="defconf: other"
                       filter add chain=input action=accept protocol=icmpv6 comment="defconf: accept ICMPv6"
                       filter add chain=input action=accept protocol=udp port=33434-33534 comment="defconf: accept UDP traceroute"
                       filter add chain=input action=accept protocol=udp dst-port=546 src-address=fe80::/16 comment="defconf: accept DHCPv6-Client prefix delegation."
                       filter add chain=input action=accept protocol=udp dst-port=500,4500 comment="defconf: accept IKE"
                       filter add chain=input action=accept protocol=ipsec-ah comment="defconf: accept ipsec AH"
                       filter add chain=input action=accept protocol=ipsec-esp comment="defconf: accept ipsec ESP"
                       filter add chain=input action=accept ipsec-policy=in,ipsec comment="defconf: accept all that matches ipsec policy"
                       filter add chain=input action=drop in-interface-list=!LAN comment="defconf: drop everything else not coming from LAN"
                       filter add chain=forward action=accept connection-state=established,related,untracked comment="defconf: accept established,related,untracked"
                       filter add chain=forward action=drop src-address-list=bad_ipv6 comment="defconf: drop packets with bad src ipv6"
                       filter add chain=forward action=drop dst-address-list=bad_ipv6 comment="defconf: drop packets with bad dst ipv6"
                       filter add chain=forward action=drop protocol=icmpv6 hop-limit=equal:1 comment="defconf: rfc4890 drop hop-limit=1"
                       filter add chain=forward action=accept protocol=icmpv6 comment="defconf: accept ICMPv6"
                       filter add chain=forward action=accept protocol=139 comment="defconf: accept HIP"
                       filter add chain=forward action=accept protocol=udp dst-port=500,4500 comment="defconf: accept IKE"
                       filter add chain=forward action=accept protocol=ipsec-ah comment="defconf: accept ipsec AH"
                       filter add chain=forward action=accept protocol=ipsec-esp comment="defconf: accept ipsec ESP"
                       filter add chain=forward action=accept ipsec-policy=in,ipsec comment="defconf: accept all that matches ipsec policy"
                       filter add chain=forward action=drop in-interface-list=!LAN comment="defconf: drop everything else not coming from LAN"
                     /ip dns {
                     /ipv6 firewall filter remove [find comment~"defconf"]
                     /ipv6 firewall address-list remove [find comment~"defconf"]
                       /ip pool {
                     /ip dns {
                     /ip address {
                     /interface wireless reset-configuration wlan1
                     /interface wireless reset-configuration wlan2
                    :set ssid;
and
                    # bridge port name
                    :global action;
                    :log info $action
                      :local count 0;
                          /quit;
                      :local macSet 0;
                      :local tmpMac "";
                          :set macSet 1;
                        # add bridge ports
                      :do {
                      :local bFirst 1;
                          /quit;
                      :delay 5s;
                          :set bFirst 0;
                        } else={
                      :do {
                      :do {
Users browsing this forum: No registered users and 120 guests
