MilanS
Virus on Mikrotik (?) + formatting (?) router
Sun Oct 07, 2018 5:52 pm
I got a message from my ISP. It says my Mikrotik router has a virus and must be formatted.
I would like to ask for little help. 2 questions:
1. Is it even possible Mikrotik can get a virus some way? I have non-default user credential since first login, so I think it must be really sofisticated to put a virus into Mikrotik.
2. Can be Mikrotik formatted? Is it same like upgrading firmware?
Feel free to ask for any additional information. I am not sure what everything is important to answer my questions.
Thank you very much.
PS: My Mikrotik model is in signature.
Milan
RouterBoard RB951G-2HnD
2frogs
Long time Member
Long time Member
Re: Virus on Mikrotik (?) + formatting (?) router
Sun Oct 07, 2018 6:48 pm
This is what happened to you:
viewtopic.php?t=133533
And I would recommend the added step of doing a Netinstall to insure your device is clean.
https://wiki.mikrotik.com/wiki/Manual:Netinstall
MilanS
Sun Oct 07, 2018 8:55 pm
Thank you very much for quick reply.
Tell me, can I check some way if the router really has a virus? I have a bad relationship with my ISP (related to invoices) and I am not sure if ISP is not trying something on me. So, can I check he is true with the virus on my router?
I tried some web check from f-secure and norton and it did not find anything.
Now I am going to study the topics and fix it. Thank you again.
Milan
msatter
Sun Oct 07, 2018 9:03 pm
Two RB760iGS (hEX S) in series. One does PPPoE and both do IKEv2.
Running:
RouterOS 6.46Beta59 / Winbox 3.20 / MikroTik APP 1.3.7
Having an Android device, use https://github.com/M66B/NetGuard/releases (no root required)
Users browsing this forum: MSN [Bot] and 110 guests
