MUM Europe 2020
jprasad
using VLAN interface as in interface for mangle rule
Fri Oct 19, 2018 6:48 pm
Hi there,
I have a number of rules in mangle. what I am finding is that if i set the in interface to reflect the correct vlan it does not mark the packets. but if I enter the IP address range in the source address fail and remove the interface then it works fine.\
I have ip firewall for vlan and ip firewall for bridges enabled
thank you
Sob
Re: using VLAN interface as in interface for mangle rule
Fri Oct 19, 2018 7:32 pm
You didn't really provide any details to work with. But you can take your IP-based rule that works, set log=yes for it, examine what gets logged and you'll see what interface the router thinks it comes from.
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply. Not intended as incentive for masochists.
Users browsing this forum: No registered users and 75 guests
