brianlewis
Firewall rules not working after hacker infection
Fri Oct 26, 2018 5:39 pm
CCR1009-8G-1S
Router was infected by hacker, had Socks enabled, scheduler running a script, service user account.
I’ve removed those but under FIREWALL the Bytes and Packets are staying ZERO. See attached M1.GIF
I can’t find anything out of the ordinary in the config.
I want to get firewall rules working again so I can lock down this router.
R1CH
Forum Veteran
Forum Veteran
Re: Firewall rules not working after hacker infection
Fri Oct 26, 2018 5:49 pm
You should netinstall with a known good config. Once a router is compromised an attacker can get system level access that you cannot detect or repair from RouterOS UI.
brianlewis
Fri Oct 26, 2018 5:53 pm
Looks like its working, had wrong 'address list subnet' for chain input so was confused why I had 0 bytes on filter rule #0
Paternot
Long time Member
Long time Member
Sat Oct 27, 2018 5:03 am
If your router was compromised, netinstall it from zero. Use a known good export to restore (the backups would be easier - but there is no way to inspect what would be restored to the router), and go from there.
In other words: nuke'm from orbit - it's the only way!
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 100 guests
