femoretti
Netinstall does'nt working(?)
Mon Oct 29, 2018 3:01 pm
Hello!
I'm trying recovery a RB951, but the NetInstall doesn't load nothing, i just click in Install, but nothing happens.
Bellow a image when i click in install
Now a image after 10s i'd clicked in install
The status of RB back to ready and nothing happens.
My Firewall are off, and antivirus too
Can anyone help me?
femoretti
Re: Netinstall does'nt working(?)
Thu Nov 08, 2018 6:13 pm
Isnt there someone can help me?
td32
Thu Nov 08, 2018 7:12 pm
try to run netinstall as admin
try another ros version like 6.42.9
Cvan
Fri Nov 09, 2018 4:38 am
Turn windows firewall off. Turn all network security stuff off. Run in Windows XP...reboot and Try that
femoretti
Mon Nov 12, 2018 3:35 pm
i do, but not worked too :/
femoretti
Mon Nov 12, 2018 3:40 pm
the firewall is off, and all network security off too. ill try run as xp compatibility.
Cvan
Tue Nov 13, 2018 2:03 am
I had the same issue. What worked for me was loading a fresh clean install of Windows XP on a laptop with no updates and plugged straight into the router RB2011. After trying Netinstall that way; the install button worked for me. Before that; it was doing the same thing you describe when clicking install.
Sorry, I forgot that there was another variable I had tried; a different version of NetInstall. At first I was using 6.42.5 and it wasn't working then I tried with 6.40.8 and it worked along with the above.
femoretti
Tue Nov 13, 2018 2:22 pm
ill try it, thanks!
cdemers
Tue Nov 13, 2018 4:58 pm
Try plugging a switch between the computer and router board. Firewall off. Set a static ip on your computer. That's how i usually do it with windows 10 and it works.
Sent from my SM-A520W using Tapatalk
Users browsing this forum: anav, Andrey05, ivicask, sergejs and 76 guests
