rzirzi
Time based firewall rule
Fri Feb 23, 2007 10:48 pm
I want to block some kind of traffic at given time.
I have created firewall rule and checked "time" at "Extra"
options, but it seems NOT working. If i disable "time"
it works (block given kind of traffic). If i enable
anch set time for that rule - it does'not wor. Why?
How to set time based rules?
maximan
Trainer
Trainer
Fri Feb 23, 2007 10:55 pm
Your clock is correct??? Use NTP client to sync the clock.
Use GMT hour
Maximiliano
MKE Solutions > Professional Support IT (Spanish / English)
FastNetMon / FNM Manager: DDoS Detection Tools.
rzirzi
Fri Feb 23, 2007 11:13 pm
Use GMT hour
Maximiliano
Thank you.
The problem was with local time. I was setting time-based
rule for local time, not for GMT. I have set it for GMT and
it's OK.
I think it's stupid setting rules for GMT, not for local time.
Thanks a lot for fast answer.
rzirzi
Sat Mar 17, 2007 10:19 pm
I have another question about Time Based Rules.
How to make rule working only beetween 23:00 to 06:00 (only at night)?
When i want to set time 23:00-06:00 - the MT is generating
answer that :"start time bigger than end time"
So - how to set this rule????
janisk
Mon Mar 19, 2007 9:07 am
apparently you will need 2 rules - 1 for 23:00-04:00 second 00:00-06:00
ManyX
Re: Time based firewall rule
Fri May 30, 2014 7:43 pm
I think that should be:
apparently you will need 2 rules - 1 for 23:00-00:00 second 00:00-06:00
rextended
Fri May 30, 2014 8:56 pm
Not, must be the first from 23:00:00 to 23:59:59 and the second from 00:00:00 to 06:00:00
or only one rule:
from 23:00:00 to 1d 06:00:00
I'm Italian, not English. Sorry for my imperfect grammar.
saintofinternet
Forum Veteran
Forum Veteran
Fri Oct 02, 2015 4:26 am
did that rule work??
by professionals, for professionals....
Don't forget to give KARMA!!!
christyjame
Sat Mar 05, 2016 5:00 pm
or only one rule:
first rule working . . .
Christyjame
dunga
Fri Apr 15, 2016 10:50 am
Hello all,
I am faced with some sort of similar problem. I was asked to block internet connectivity in a mikrotik router and allow traffic from some time.
What I want is to allow traffic or internet connectivity from 7:00 - 16:00 but block internet connectivity on the network from 17:00 to 6:00am.
I need the steps or firewall to achieve this step.s
soonwai
Fri Apr 15, 2016 1:23 pm
Users browsing this forum: Google Feedfetcher, Majestic-12 [Bot], mirk, txfz and 96 guests
