blackmetal
rules order in raw firewall change
Sat Nov 03, 2018 11:34 am
we have some CCR 1036 and we have some raw firewall rules in our ccr's when we reboot the router or in such special case rules order will change. so is there anyway save rules order in raw firewall filtering?
because i have some rules for block special ports and when the rules order change my router cpu will increase up to %50.
thank you.
xvo
Re: rules order in raw firewall change
Sat Nov 03, 2018 12:55 pm
It shouldn't change on its own.
blackmetal
Sat Nov 03, 2018 1:13 pm
they should not yes, but i have this issue and also they will be upper of dynamic rules in raw tab
xvo
Sat Nov 03, 2018 2:49 pm
Are you sure they aren't just sorted?
AlainCasault
Trainer
Trainer
Sat Nov 03, 2018 2:57 pm
Agreed. I do that sometime by mistake. Just click on the sequencial numbers column and it should be ok.
Sent from Tapatalk
___________________________
Alain Casault, Eng.
If I helped you, let me know!
mozerd
Sat Nov 03, 2018 3:00 pm
If you rules order has changed without your knowledge it means your system is compromised. I suggest that you NETINSTAL and start fresh.
blackmetal
Sat Nov 03, 2018 3:04 pm
we have several ccr and all of them has same issue so its not related to one device
mkx
Sat Nov 03, 2018 4:15 pm
You're mentioning dynamic rules ... those obviously don't survive reboots. If you want those higher than static rules, you have to push them up when creating them.
BR,
Metod
mozerd
Sat Nov 03, 2018 6:11 pm
The number of CCR in place is not relevent = and if all your CCR's are displaying the exct same behaviour then you need to correct the issue for all of them. Make sure that your scripts, assuming you have some scripts that fire based on some condition, are correctly done. If no scipts exists and youir rule order canges without your implied consent THAT usually indicates someone [processes] is making changes a sure sign that your machines have been taken over. Netinsall is the safe way to bring back sanity to your CCR's.
blackmetal
Sat Nov 03, 2018 6:16 pm
how can i manage dynamic rules that be always top of my rules after restart?
blackmetal
Sat Nov 03, 2018 6:17 pm
all of our routers has private ip and they have winbox ip limitation and firewall protection and if somebody touch my router why does he only touch rules order! if i have access to a router sure i will change password :P and i have checked the logs there is no log in my syslog server that some one login to my router illigaly
mkx
Sat Nov 03, 2018 9:20 pm
Depends how rules get added. With /ip firewall raw add you can use place-before=x ... where x is place where you want to put the new rule. If the rules are created and you can not influence the order, you can write a script which pushes all dynamic rules before static ones ... and run that script every minute or so ...
BR,
Metod
Users browsing this forum: No registered users and 92 guests
