MUM Europe 2020
jmginer
Firmware upgrade?
Mon Nov 05, 2018 10:30 am
Hello!
When we do a software update, the system marks the firmware as outdated. Is it always necessary to do a double reboot? or is it possible to update the software and firmware in the same reboot?
Thank you!
victorsoares
Re: Firmware upgrade?
Mon Nov 05, 2018 1:52 pm
Usually I do the firmware upgrade first, since it waits for you to reboot, and then I do the software upgrade. Only after that I'll reboot the system. I never had any problems doing this, but I'm not sure if it is the correct way.
MTCNA MTCRE
R1CH
Forum Veteran
Forum Veteran
Mon Nov 05, 2018 6:24 pm
This is an unfortunate side effect of the new firmware version scheme. The firmware version always shows the same as RouterOS version now, even if there have been no changes between the previous firmware version. The only way to know for sure if there's really been an update is to read through changelog. I also worry that constant re-installation of the same firmware over and over will eventually wear out the NAND on the RouterBOOT partition, so it's best to update only if you need to.
mkx
Mon Nov 05, 2018 6:31 pm
How can you update firmware first and software later? Isn't firmware package part of software and is not available until after software is upgraded?
BR,
Metod
Users browsing this forum: eworm, grantmu, liviu2004, stanisljevic, Zmer and 112 guests
