Is that total throughput or per queue? I would like to use simple queus or queue tree per user, up to 600Mbit...
What do you recomend for Hypervisor?
Re: … Is that total throughput …
I am saying (from my prior post) that simple queue settings of 4294M or less are accepted in the Mikrotik ROS configuration. Attempts to set a simple queue higher/faster than 4294M are rejected (the winbox entry just turns red when 4295M or faster is typed in.
As for the simple queue properly rate limiting at speeds of 4294M or slower , it works very well --- providing you have a physical box with 10-Gig physical network cards and you have the CPU horsepower.
My physical server is a SuperMicro running VmWare ESXi and the Mikrotik ROS CHR is using the VMXNET-3 network card.
FYI - re CHR throughput on a hypervisor ... On your CHR , do a UDP (send or receive) btest to 127.0.0.1 , you should be able to hit at least 15-Gig. A good box should hit at least 20-Gig. A screaming fast box should be close to 25-Gig or faster.
North Idaho Tom Jones
