Jotne
Manual:Bridge VLAN Filtering with Visio figures (6.41+)
Tue Nov 13, 2018 10:00 am
This is just a copy from the manual. It shows how to setup VLAN using 6.41+ Bridge VLAN Filtering.
https://wiki.mikrotik.com/wiki/Manual:I ... _Filtering
If you find any error, please let me now so that I can correct it.
I will add more example with configuration and Visio later
VLAN Example #1 (Trunk and Access Ports)
Create a bridge with disabled vlan-filtering to avoid losing access to the router before VLANs are completely configured.
add name=bridge1 vlan-filtering=no
Add bridge ports and specify pvid for VLAN access ports to assign their untagged traffic to the intended VLAN.
add bridge=bridge1 interface=ether6 pvid=200
add bridge=bridge1 interface=ether7 pvid=300
add bridge=bridge1 interface=ether8 pvid=400
Add Bridge VLAN entries and specify tagged and untagged ports in them.
/interface bridge vlan
add bridge=bridge1 tagged=ether2 untagged=ether6 vlan-ids=200
add bridge=bridge1 tagged=ether2 untagged=ether7 vlan-ids=300
add bridge=bridge1 tagged=ether2 untagged=ether8 vlan-ids=400
In the end, when VLAN configuration is complete, enable Bridge VLAN Filtering.
/interface bridge set bridge1 vlan-filtering=yes
Warning: The PVID value is set to all traffic that enters the bridge and adds the port dynamically to the bridge VLAN table for VLAN ID that matches the PVID value. If you are trying to isolate tagged traffic from untagged traffic, then make sure you have set a PVID to a bridge port that is different from the bridge's PVID value, otherwise these ports will be dynamically added to the bridge VLAN table and will be able to forward traffic from untagged ports.
Try Splunk> to monitor your MikroTik Router(s). How to set it up. :mrgreen:
MikroTik->Splunk
Jotne
Re: Manual:Bridge VLAN Filtering with Visio figures
Tue Nov 13, 2018 10:03 am
VLAN Example #2 (Trunk and Hybrid Ports)
Add bridge ports and specify pvid on hybrid VLAN ports to assign untagged traffic to the intended VLAN.
Add Bridge VLAN entries and specify tagged and untagged ports in them. In this example egress VLAN tagging is done on ether6,ether7,ether8 ports too, making them into hybrid ports.
add bridge=bridge1 tagged=ether2,ether7,ether8 untagged=ether6 vlan-ids=200
add bridge=bridge1 tagged=ether2,ether6,ether8 untagged=ether7 vlan-ids=300
add bridge=bridge1 tagged=ether2,ether6,ether7 untagged=ether8 vlan-ids=400
MikroTik->Splunk
Jotne
Tue Nov 13, 2018 10:05 am
VLAN Example #3 (InterVLAN Routing by Bridge)
Add Bridge VLAN entries and specify tagged and untagged ports in them. In this example bridge1 interface is the VLAN trunk that will send traffic further to do InterVLAN routing.
add bridge=bridge1 tagged=bridge1 untagged=ether6 vlan-ids=200
add bridge=bridge1 tagged=bridge1 untagged=ether7 vlan-ids=300
add bridge=bridge1 tagged=bridge1 untagged=ether8 vlan-ids=400
Configure VLAN interfaces on the bridge1 to allow handling of tagged VLAN traffic at routing level and set IP addresses to ensure routing between VLANs as planned.
/interface vlan
add interface=bridge1 name=vlan200 vlan-id=200
add interface=bridge1 name=vlan300 vlan-id=300
add interface=bridge1 name=vlan400 vlan-id=400
add address=20.0.0.1/24 interface=vlan200 network=20.0.0.0
add address=30.0.0.1/24 interface=vlan300 network=30.0.0.0
add address=40.0.0.1/24 interface=vlan400 network=40.0.0.0
MikroTik->Splunk
Jotne
Tue Nov 13, 2018 10:09 am
Management port #1
(This is based on previous configutatin)
There are multiple ways to setup management port on a device that uses bridge VLAN filtering. Below are some of the most popular approaches to properly enable access to a router/switch. Start by creating a bridge without VLAN filtering enabled:
In case VLAN filtering will not be used and access with untagged traffic is desired
The only requirement is to create an IP address on the bridge interface.
add address=192.168.99.1/24 interface=bridge1
After that you can enable VLAN filtering:
MikroTik->Splunk
Jotne
Tue Nov 13, 2018 10:11 am
Management port #2
In case VLAN filtering is used and access from trunk and/or access ports with tagged traffic is desired
In this example VLAN 99 will be used to access the device, a VLAN interface on the bridge must be created and an IP address must be assigned to it.
/interface vlan
add interface=bridge1 name=MGMT vlan-id=99
add address=192.168.99.1/24 interface=MGMT
This is missing for the manual and need to be added so the interface do communicate with the bridge
add bridge=bridge1 interface=ether3 pvid=1
add bridge=bridge1 interface=ether4 pvid=1
add bridge=bridge1 interface=sfp pvid=1
For example, if you want to allow access to the router/switch from access ports ether3,ether4 and from trunk port sfp-sfpplus1, then you must add this entry to the VLAN table:
add bridge=bridge1 tagged=bridge1,ether3,ether4,sfp-sfpplus1 vlan-ids=99
MikroTik->Splunk
Jotne
Tue Nov 13, 2018 10:13 am
Management port #3
In case VLAN filtering is used and access from trunk and/or access ports with untagged traffic is desired
To allow untagged traffic to access the router/switch, start by creating an IP address on the bridge interface.
add address=192.168.88.1/24 interface=bridge1
It is required to add VLAN 1 to ports from which you want to allow the access to the router/switch, for example, to allow access from access ports ether3,ether4 add this entry to the VLAN table:
add bridge=bridge1 untagged=ether3,ether4 vlan-ids=1
Make sure that PVID on the bridge interface matches the PVID value on these ports:
/interface bridge set bridge1 pvid=1
/interface bridge port set ether3,ether4 pvid=1
MikroTik->Splunk
Jotne
Re: Manual:Bridge VLAN Filtering with Visio figures (6.41+)
Wed Nov 14, 2018 8:26 pm
Manual:Basic VLAN switching
Other devices without a built-in switch chip. https://wiki.mikrotik.com/wiki/Manual:B ... witch_chip
It is possible to do VLAN filtering using the CPU, there are multiple ways to do it, but it is highly recommended by using bridge VLAN filtering.
Here the MT is configured as a switch with VLAN 20,30 and 99 Tagged on Port 1. VLAN 20 untagged on Port 2. VLAN 30 untagged on Port 3.
add name=bridge1
add bridge=bridge1 interface=ether1 hw=no
add bridge=bridge1 interface=ether2 hw=no pvid=20
add bridge=bridge1 interface=ether3 hw=no pvid=30
add bridge=bridge1 tagged=ether1 untagged=ether2,ether3 vlan-ids=20,30
add bridge=bridge1 tagged=ether1,bridge1 vlan-ids=99
/interface vlan
add interface=bridge1 vlan-id=99 name=MGMT
MikroTik->Splunk
Users browsing this forum: Ahrefs [Bot], alkar, Bing [Bot], Majestic-12 [Bot], mmcpheet, pacmanfan and 19 guests
