OlofL
Any success with ansible over SSH in 2018?
Tue Nov 13, 2018 6:08 pm
Hello, Im trying to do some simple ansible scripts to push some config to routeros.
Im on routeros 6.43 and ansible 2.7 and trying the ansible modules: raw, command and the new routeros_command https://docs.ansible.com/ansible/latest ... odule.html. None succeeeds, and they just hang. Full debug shows its just hangs on this command:
<172.16.179.1> SSH: EXEC ssh -vvv -C -o ControlMaster=auto -o ControlPersist=60s -o StrictHostKeyChecking=no -o KbdInteractiveAuthentication=no -o PreferredAuthentications=gssapi-with-mic,gssapi-keyex,hostbased,publickey -o PasswordAuthentication=no -o ConnectTimeout=10 -o ControlPath=/home/olof/.ansible/cp/5edf2db020 -tt 172.16.179.1 '/ip address print'
I have tried using -u user and --ask-pass but normally use ssh keys. Both result in the same failure.
Some examples:
ansible mikrotik -m command -a "executable= /ip address print"
 [WARNING]: sftp transfer mechanism failed on [172.16.179.1]. Use ANSIBLE_DEBUG=1 to see detailed information
 [WARNING]: scp transfer mechanism failed on [172.16.179.1]. Use ANSIBLE_DEBUG=1 to see detailed information
raw module...
ansible mikrotik -m raw -a "/ip address print"
and in a playbook
playbook.yml
- hosts: mikrotik
  gather_facts: no
  tasks:
  - name: Display resource statistics (routeros)
    raw:
      commands: /system routerboard print
#      wait_for: result[0] contains MikroTik
#    register: routeros_resources
normal SSH works fine with no magic needed.
ssh 172.16.179.1 "ip addr pri"
 #   ADDRESS            NETWORK         INTERFACE
 0   172.24.31.242/29   172.24.31.240   ether1
djdrastic
Re: Any success with ansible over SSH in 2018?
Thu Nov 29, 2018 10:29 pm
Mi mate did you ever manage to sort this out ? Running to a similar issue atm.
gilito
Mon Dec 24, 2018 4:37 pm
Hello!
I'm in learning phase, but I can say something
For using raw commands, you need to edit ansible.cfg and uncomment this line
Code: Select all
[paramiko_connection]
And config connectino plugin by paramiko
# by default, Ansible requests a pseudo-terminal for commands executed under sudo. Uncomment this
# line to disable this behaviour.
pty=False
To use routeros_commands you must configure as connection: network_cli
example:
root@ansible:~# cat mikrotik.yml
Code: Select all
- name: Test routers_commands
hosts: your hosts list
remote_user: you_username
gather_facts: false
tasks:
- name: run command on remote devices
routeros_command:
- name: run command and check to see if output contains routeros
routeros_command:
commands: /system resource print
- name: run multiple commands on remote nodes
routeros_command:
commands:
- /system routerboard print
- /system identity print
To run it:
Code: Select all
ansible-playbook mikrotik.yml -k
-k for entering ssh password
I don't understand alot, but the best is using routeros_commands, nor raw connections
bye!
seraph88
Tue Nov 05, 2019 2:48 pm
i have a problem with connection to mikrotik via ansible.
my mikrotik yaml file:
  hosts: mikrotik
  ansible_network_os: routeros
  remote_user: mikrotik_user
  gather_facts: false
  tasks:
  routeros_command:
after save this file i run ansible like below:
ansible-playbook  mikrotik_test.yaml  -k
and i recive this:
ERROR! 'commands' is not a valid attribute for a Play
The error appears to have been in '/etc/ansible/mikrotik_test.yaml': line 2, column 3, but may
be elsewhere in the file depending on the exact syntax problem.
The offending line appears to be:
  ^ here
Please help because i sit on this all day and i have no idea what am i doing wrong.
LewisH95
Thu Nov 07, 2019 4:20 pm
SSH KEYS ARE YOUR FRIENDS
Passwords are supported, but SSH keys with ssh-agent are one of the best ways to use Ansible. ... Ansible's "authorized_key" module is a great way to use ansible to control what machines can access what hosts. Other options, like kerberos or identity management systems, can also be used.
Hope this information helps!
Regards,
Lewis
Users browsing this forum: No registered users and 99 guests
