minfrin
How do you use ssh agent forwarding on the routeros ssh client?
Thu Nov 15, 2018 7:35 pm
Hi all,
I have routerboard B, that I need to ssh to via routerboard A. All user accounts are protected by SSH keys.
I am struggling to get ssh agent forwarding to work. When I log into routerboard A I can log into successfully, but when I log into routerboard B I am asked for a password, when I should log in automatically using agent forwarding.
The AllowAgentForwarding option on the sshd server makes this happen, how do I switch this on?
Regards,
Graham
lambert
Long time Member
Long time Member
Re: How do you use ssh agent forwarding on the routeros ssh client?
Fri Nov 16, 2018 1:37 am
It is not an option.
The options are:
/ip ssh set
Change properties of one or several items.
always-allow-password-login -- allow password login when public key authorization is configured
forwarding-enabled -- allows clients to connect to remote ports from server
host-key-size -- RSA key size when host key ir regenarated
strong-crypto -- use stronger encryption, HMAC algorithms, use bigger DH primes and disallow weaker ones
I suppose you could port forward to the second router and connect to it directly from your workstation on the non-standard port, but that may not be allowed due to management policy.
minfrin
Fri Nov 16, 2018 12:43 pm
How do I get this supported by Mikrotik?
We have a strict no password policy, and the inability to forward keys make it difficult for us to enforce that policy.
janisk
Fri Nov 16, 2018 3:04 pm
use SSH ProxyCommand to set up SSH login to hosts that are behind the other SSH host.
minfrin
Mon Nov 19, 2018 12:18 pm
Unfortunately port forwarding (whether using the command line or config) only allows you to jump one step past a mikrotik, and is therefore not useful in a secure environment.
Can you confirm when SSH agent forwarding will be supported?
lambert
Long time Member
Long time Member
Mon Nov 19, 2018 7:01 pm
If you don't want to wait, VPNs, with as much crypto as SSH, are available now. I have run VPNs inside VPNs to get inside multiple layers of firewalls.
kiwibrew
Fri Mar 22, 2019 4:39 am
This is also important to me. Since shifting to 100% keys this has made it very, very difficult to work with some VPN-connected devices.
HouleJm
Fri Mar 22, 2019 7:52 am
Hi all,
Regards,
Graham
It allows you to use your local SSH keys instead of leaving keys without passphrases sitting on your server.
eworm
Long time Member
Long time Member
Fri Mar 22, 2019 5:21 pm
You can use your Mikrotik devices as Jumphost. Just search for this keyword for details.
Example for openssh command line client:
ssh -J Mikrotik-A Mikrotik-B
You can use a chain with more than one jumphost.
Manage RouterOS scripts and extend your devices' functionality: RouterOS Scripts
HouleJm
Sat Mar 23, 2019 1:25 pm
Let's configure and test SSH forwarding using github as remote service to pull our code into the host MyBKExperience.
Users browsing this forum: atlanticd, xiaotuzi and 89 guests
