alger
How to secure port on the switch?
Fri Nov 16, 2018 9:29 am
Hello
A simple network where RB2011 is used as a switch. How to make on ether1 it was possible to connect other switch only with the MAC address 11:11:11:11:11:11 on the port, without filtering the MAC addresses of the devices connected to switch1?
Alexander
sebastia
Re: How to secure port on the switch?
Sat Nov 17, 2018 12:29 am
don't understand your question. Note that switches don't have macs only network devices.
k6ccc
Sat Nov 17, 2018 12:54 am
Wow! I'm going to have to tell all my switches that they don't really have a MAC. That will be a shock to them. How do you suppose layer two works without a MAC?
RB750Gr3, RB750r2, CRS326-24G-2S (in SwitchOS), CSS326-24G-2S, CSS106-5G-1S, RB260GS
Not sure if I beat them in submission, or they beat me into submission
Jim
anav
Sat Nov 17, 2018 1:14 am
Only MacDonalds switches have Mac's, their managed switches have Big Macs.
{Edit - my apologies for the non-North American audience members that did not relate to the McDonalds humour, or should I say my bad attempt at humour! :-) }
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
sebastia
Sat Nov 17, 2018 1:52 am
I would suggest to go back to network school... And don't try to insult others, if you don't know any better either...
A switch in its pure form (as in unmanaged switch) doesn't have mac on it's ports. Only devices which actually participate in communication such as nics do.
This lesson was free of charge.
vecernik87
Long time Member
Long time Member
Sat Nov 17, 2018 2:39 am
It does not really matter if switch has or does not have MAC. All it matters is, that switch does not modify packet - it just forward it to correct port.
So unless OP is talking about blocking communication of switch itself (that seems rather unusual, more likely he wants to block communication of devices which are behind that switch), then there is no way to find out from packet, whether it went through switch with mac 11:11:11:11:11:11 or 22:22:22:22:22:22.
anav
Sat Nov 17, 2018 5:06 pm
I believe the question from the first response (sebastia) is the proper one. Understanding of the question is the key.
If the OP can explain what he/she is attempting to provide (without resorting to design or solution), or in other jargon, describe the use case, then we can start to apply networking acumen and mikrotik programming to see if there is a design/solution that fits. (by the way, the networking acumen and mikrotik programming is for others not me....... i just am interested in properly understanding the requirements first and foremost). I could care less about switch mac, switch cheese, or switchest witch in the east, until I understand the naked issues.
mkx
Sat Nov 17, 2018 5:44 pm
Until OP provides authentic explanation of his intentions ... I'll dare to speculate: he wants to make sure that physical device which connects directly to port ether1 of RB is indeed switch with it's management interface's MAC being 11:11:11:11:11:11 ...
I guess there's no fool proof way of doing it. As @sebastia already explained switches don't change packets on transit. If RB receives a packet with src MAC address of that switch it doesn't mean that there's no switching equipment in between (I'm pretty sure that a linux box with two NICs could be made to act as transparent bridge/switch that sniffs all traffic ... but one couldn't easily detect its presence).
BR,
Metod
anav
Sat Nov 17, 2018 7:37 pm
So brave! ;-)
(a budding fiction novelist in the making too)
Users browsing this forum: No registered users and 100 guests
