MichaelTrip
IPv6 fe80 address get changed on every reboot
Mon Nov 19, 2018 7:26 pm
Every time i reboot my RB2011UiAS-2HnD the fe80 ipv6 address changes. I use a bridge interface as my wan interface. How to fix this?
sebastia
Re: IPv6 fe80 address get changed on every reboot
Mon Nov 19, 2018 10:16 pm
Hello
fe80 is a link local ip. You should have received a routeable ipv6 from your isp: either static, ra or dhcp. Use that one.
MichaelTrip
Wed Dec 05, 2018 1:21 pm
I have a static route on my router from my ISP that routes a /54 to my Mikrotik. I can only route on my fe80 address, so now i have to change my routes every time my Mikrotik reboots.
mducharme
Trainer
Trainer
Wed Dec 05, 2018 1:22 pm
Manually set the MAC on the bridge interface, then the fe80 address should not change. The fe80 address is derived from the MAC address, so your bridge MAC must be changing, otherwise the fe80 would not change.
MichaelTrip
Wed Dec 05, 2018 2:28 pm
Thanks for your answer. That seems to work!
Users browsing this forum: amt, Baidu [Spider], Google [Bot] and 34 guests
