blingblouw
Mikrotik SNMP Wireless Values different
Thu Nov 29, 2018 5:03 pm
Hi.
I'm pretty new to monitoring straight SNMP OID's however I am having a hard time plotting Mikrotik WIFI devices. The reason for this is the OID changes.
For example
RB SXT 5nD r2
[admin@Mikrotik] > interface wireless print oid
 0 tx-rate=.1.3.6.1.4.1.14988.1.1.1.3.1.2.2 rx-rate=.1.3.6.1.4.1.14988.1.1.1.3.1.3.2 ssid=.1.3.6.1.4.1.14988.1.1.1.3.1.4.2 bssid=.1.3.6.1.4.1.14988.1.1.1.3.1.5.2
   client-count=.1.3.6.1.4.1.14988.1.1.1.3.1.6.2 frequency=.1.3.6.1.4.1.14988.1.1.1.3.1.7.2 band=.1.3.6.1.4.1.14988.1.1.1.3.1.8.2 noise-floor=.1.3.6.1.4.1.14988.1.1.1.3.1.9.2
   overall-ccq=.1.3.6.1.4.1.14988.1.1.1.3.1.10.2
[admin@Mikrotik] > /sys router print
       routerboard: yes
             model: SXT 5nD r2
     serial-number: 522301036354
  current-firmware: 3.22
  upgrade-firmware: 3.24
Then on on another device (same model)
[admin@cs-11onBuiten] > int wire print oid
 0 tx-rate=.1.3.6.1.4.1.14988.1.1.1.1.1.2.2 rx-rate=.1.3.6.1.4.1.14988.1.1.1.1.1.3.2 strength=.1.3.6.1.4.1.14988.1.1.1.1.1.4.2 ssid=.1.3.6.1.4.1.14988.1.1.1.1.1.5.2
   bssid=.1.3.6.1.4.1.14988.1.1.1.1.1.6.2 frequency=.1.3.6.1.4.1.14988.1.1.1.1.1.7.2 band=.1.3.6.1.4.1.14988.1.1.1.1.1.8.2
[admin@cs-11onBuiten] > sys router pr
       routerboard: yes
             model: SXT 5nD r2
     serial-number: 5E9A05A2DF13
  current-firmware: 3.24
Does Mikrotik change OID's per RouterOS Version? Is there no sane way to monitor things?
blingblouw
Re: Mikrotik SNMP Wireless Values different  [SOLVED]
Thu Nov 29, 2018 5:12 pm
Always happens when you post something and you figure it out.
It changes based on wireless mode. station, station-bridge.
Jotne
Thu Nov 29, 2018 8:36 pm
Not sure what RouterOS you ar running, but firmware is very old.
You should upgrade.
BeardyTechie
Wed Sep 08, 2021 2:59 pm
Hi, I'm new to Mikrotik so please bear with me
I've got a wireless-wire pair of 60GHz APs, and am trying to record the signal strengths over time using Zabbix. I've got lots of other metrics being graphed but I don't know the OIDs for wifi signal strength. the command suggested above didn't work:
[admin@rbwapg-master] > interface wireless print oid
thanks for any ideas.
these are the interfaces:
[admin@rbwapg-master] > interface print
 #     NAME                                TYPE       ACTUAL-MTU L2MTU  MAX-L2MTU MAC-ADDRESS
 0  RS ether1                              ether            1500  1598       9214 aa:bb:cc:dd:13
 1     wlan60-1                            wlan60-          1500  1600       7882 aa:bb:cc:dd:7E:14
 2  R  ;;; defconf
       bridge                              bridge           1500  1598            aa:bb:cc:dd:7E:13
 3  RS ether1-vlan41                       vlan             1500  1594            aa:bb:cc:dd:7E:13
 4  R  pppoe                               bridge           1500  1594            aa:bb:cc:dd:7E:13
 5  RS wlan60-1-vlan41                     vlan             1500  1596            aa:bb:cc:dd:7E:14
 6  RS wlan60-station-1                    wlan60-...       1500  1600            aa:bb:cc:dd:7E:14
Users browsing this forum: No registered users and 138 guests
