sergis
b6 simple queue
Thu Mar 01, 2007 1:31 pm
looks like simple queue not working on beta 6 on routerboard.
When i add limit to ip: 10.0.0.2 and set ul/dl to 512kb/sec this limit aplies to all network,qos traffic shows real this ip data rate,but packet rate 38 310 and 27071,at this moment this computer is turned off.. :shock:
sergejs
Thu Mar 01, 2007 1:42 pm
Could you provide us with exact syntax of the created 'queue simple' entry ?
sergis
Thu Mar 01, 2007 2:03 pm
/queue simple add direction=both disabled=no dst-address=0.0.0.0/0 interface=all limit-at=0/0 max-limit=512000/512000 name="test" parent=none priority=8 queue=default-small/default-small target-addresses=10.0.0.2/32 total-queue=default-small
sergis
Thu Mar 01, 2007 2:10 pm
sergejs
Thu Mar 01, 2007 2:12 pm
Thank you we will check this.
pekr
Thu Mar 01, 2007 5:45 pm
What's to wonder here, Sergejs? It does not work from beta5 already, no? ;-) It uses "strange" format of 10.10.10.10-255.255.255.255 format (after upgrade) - is that the default format? And once you go into console, it shows nonsense like 10.10.10.10/31 :-)
I will try to upgrade to beta6 to see what changed ...
-pekr-
sergejs
Thu Mar 01, 2007 5:46 pm
'queue simple' entry should work fine, it looks like 'chart' problem, as we have tried on site, queue simple entry is limiting bandwith correctly.
Users browsing this forum: anav, beeyev, Bing [Bot], biomesh, dave864, harvey, sindy and 71 guests
