Sohraab
Port Forwarding Not Working
Thu Dec 06, 2018 1:11 am
Hello All,
I have set up a VOIP server with address 10.10.1.1 .
Also i have VOIP service that comes from VOIP Provider in a private network (VOIP Gateway Address 10.105.20.134) and i have set up 10.123.232.61/24 on my router. I can ping voip gateway ip address fine.
Now i need some rule to receive request from voip provider same as this
0 chain=dstnat action=dst-nat to-addresses=10.10.1.1 to-ports=5060
protocol=udp src-address=10.105.20.134 dst-address=10.123.232.61
dst-port=5060 log=no log-prefix=""
But does not work :(
I used Torch for monitoring interface
# Eth. Protocol Protocol Src. Dst. VLAN Id DSCP Tx Rate Rx Rate Tx Packet Rate Rx Packet Rate
0 800 (ip) 17 (udp) 10.105.20.134:5060 (sip) 10.123.232.61:5060 (sip) 0 bps 3.1 kbps 0 0
Where is my mistake?
sebastia
Re: Port Forwarding Not Working
Thu Dec 06, 2018 1:30 am
Hi
The forward needs to be allowed in filter table too. In default config, it's done auto for all "dst-nat"-ed connections. If you have modified it, you need to allow it.
/ip firewall filter add chain=forward ...
Sohraab
Thu Dec 06, 2018 1:53 am
Thanks for your replay.
There is no rule in filter table.
sebastia
Thu Dec 06, 2018 1:58 am
would you mind posting your config?
"/export hide-sensitive compact"
Sohraab
Thu Dec 06, 2018 2:16 am
# model = CCR1036-12G-4S
# serial number = 76C182F2Y7S9
set [ find default-name=ether1 ] disabled=yes
set [ find default-name=ether2 ] name=ether2-Clients
set [ find default-name=ether3 ] name=ether3-pbx
set [ find default-name=ether11 ] name=ether11-tctvoip
set [ find default-name=ether12 ] name=ether12-internet
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether12-internet name=\
internet user=aaa
add name=dhcp_pool0 ranges=192.168.26.1-192.168.26.100
add address-pool=dhcp_pool0 disabled=no interface=ether2 lease-time=\
3d10m name=dhcp1
/tool user-manager customer
set admin access=\
own-routers,own-users,own-profiles,own-limits,config-payment-gw
/interface detect-internet
set detect-interface-list=all
/interface pptp-server server
set enabled=yes
add address=10.10.1.254/24 interface=ether3-pbx network=10.10.1.0
add address=10.123.232.61/24 interface=ether11-tctvoip network=10.123.232.0
add address=192.168.26.254/24 interface=ether2-Clients network=192.168.26.0
/ip dhcp-client
add add-default-route=no dhcp-options=hostname,clientid disabled=no interface=\
ether11-tctvoip use-peer-dns=no use-peer-ntp=no
add address=192.168.26.0/24 dns-server=10.2.1.1,4.2.2.4,8.8.8.8 gateway=\
192.168.26.254
add action=dst-nat chain=dstnat comment="tct voip----> local voip server" \
dst-address=10.123.232.61 dst-port=5060 protocol=udp src-address=\
10.105.20.134 to-addresses=10.10.1.1 to-ports=5060
add action=masquerade chain=srcnat comment="VOIP server<====>Clients" \
dst-address=10.10.1.1 out-interface=ether2-Clients src-address=\
192.168.26.0/24
add action=masquerade chain=srcnat comment="my laptop" out-interface=\
internet src-address=192.168.26.11
add action=src-nat chain=srcnat dst-address=192.168.100.1 src-address=\
192.168.26.11 to-addresses=192.168.100.1
add action=masquerade chain=srcnat src-address=1.1.1.2
add check-gateway=ping distance=1 gateway=10.123.232.1 routing-mark=TEST
add comment="To tct gateway" distance=1 dst-address=10.105.20.134/32 gateway=\
10.123.232.1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www address=51.37.172.106/23 disabled=yes port=8021
set ssh disabled=yes
set winbox port=23321
set api-ssl disabled=yes
/ppp secret
add local-address=1.1.1.1 name=sohraab remote-address=1.1.1.2 service=pptp
anav
Thu Dec 06, 2018 3:51 am
These look all wrong to me..........
192.168.26.0/24
Plus dont see any firewall rules and thus the config is not ready to put on the net!
(in the forward chain of firewall rules you would want this one)
action=accept chain=forward comment=\
"Allow Port Forwarding - DSTNAT" connection-nat-state=dstnat
sebastia
Thu Dec 06, 2018 2:44 pm
Some observations
# You know what your internet interface is => pppoe, would suggest to disable it as it caused issues in other instances
# There is a fixed ip set & dhcp together? dhcp-client can / should probably be disabled/removed.
/ip dhcp-client
# out interface is .26. and src too?, is that even needed both have router as default gateway anyway
192.168.26.0/24
# you should remove the src-address, as you want all traffic to be masqueraded
# .100. address is not set on this router. This rule should be removed.
# 1.2 address is not set on this router. This rule should be removed.
# This one is currently unused
currently there is no filtering at all: so once dstnat-ed it will pass to voip -> pbx. but in reverse there is also translation needed, src-nat pbx -> voip
add action=src-nat chain=srcnat out-interface=ether11-tctvoip to-addresses=10.123.232.61
you would want to secure the router if connected to internet: see https://wiki.mikrotik.com/wiki/Manual:S ... our_Router
Users browsing this forum: amt and 30 guests
