nocontrol
Cannot upgrade at all!
Mon Dec 10, 2018 5:19 pm
I am trying to upgrade my mikrotik router and after successfully rebooting, I am still in the old version. Is there any way I can troubleshoot this?
nickshore
Re: Cannot upgrade at all!
Mon Dec 10, 2018 5:55 pm
Is there anything in the logs ?
Nick Shore MTCNA MTCWE MTCRE MTCINE MTCTCE
LinITX.com - MultiThread Consultants
Get your MikroTik RBs and Training: http://linitx.com/brand/mikrotik
Official UK MikroTik Distributor
IRC chan: #routerboard on irc.z.je (IPv4 and IPv6)
nocontrol
Mon Dec 10, 2018 6:21 pm
Nope. The logs are clear of any failure message.
I have downloaded a new firmware and manually installed it, tried to install a beta or a stable version etc.
I've even tried the disk space patch by Mikrotik. It still reboots and I am in the same version.
The only suspicious thing is that I have two "security" packages in the Packages section, both disabled. I am trying to enable the first and uninstall the second but it doesn't work.
There are still there, no matter what I am choosing.
nickshore
Mon Dec 10, 2018 6:28 pm
Make sure you have set the logging to disk and try again
nocontrol
Mon Dec 10, 2018 6:37 pm
I see things in logs but only related to connections and networking. What am I expecting to see?
mkx
Mon Dec 10, 2018 10:59 pm
There have been numerous reports about duplicate packages installed (one from bundle and one from separate package) and such state doesn't allow administrator to do anything related to packages (including up&down grade). The only solution out of such mess seems to be netinstall. You can save a fresh backup before start, then netinstall device with the same version of ROS (this should fix duplicate packages), restore config and then proceed with ROS upgrade.
BR,
Metod
nocontrol
Fri Dec 14, 2018 1:37 pm
That was really good. I guess that it seems hard from the outside but If you go through the process once, it's just easy as a game.
Backed up, netinstalled, Restore - All systems running and updated. The more I get used to it and fix problems, the more I love it.
Thank you.
SiB
Fri Dec 14, 2018 8:42 pm
I can confirm that.
I have 2 devices who are not possibility to update/downgrade at all. They are works properly.
Logs give me only info about "system,error,critical router was rebooted without proper shutdown" - I reboot it from WinBox&CLI etc. and no any effect.
NETINSTALL fix all.
MTCNA + MTCRE + MTCINE | ~600 users at ~150 RouterBoards in EMEA | Telegram: @SiB_PL | WebChat: Tokonda
WinBox Tip: F6 works as ALT+TAB | Gliffy.com - free network schematic | prnt.sc - free ScreenShot software
Users browsing this forum: MSN [Bot] and 83 guests
