n4p
Ipsec Site to Site with certificate
Mon Dec 10, 2018 9:59 pm
Hi
I try to configure a connection between two ccr1009 and encrypt this with ipsec.
If I try to use psk everything works fine. But I wanna use instead certificates. I search for some time but I didn't found any tutorial how to do this.
So I wanna ask would this be possible?
anwlab
Re: Ipsec Site to Site with certificate
Tue Dec 11, 2018 11:17 pm
Same to me.
Trying to connect RB951G with SonicWall NSA2400. IKEv2 PSK mode works fine, certificate - no. Sonicwall says "IKEv2 Unable to find IKE SA" and "IKEv2 Payload processing error".
Mikrotik says - "remote peer connection established" and resets connection in 30-40 sec.
anwlab
Wed Dec 12, 2018 12:38 am
Found weird issue. My-id been set as WAN IP address, not auto. But as I can see in ipsec log, mikrotik did not set address there. It replaced with DN. RouterOS 6.43.7.
n4p
Tue Dec 18, 2018 9:55 pm
Any news about that? Still trying around but no chance to get it working.
Only Log-Entry shown is: Can't get private key.
So what is wrong there?
I created a certificate for server (tls-server) and another one for the client (tls-client) installed on the client the certificate and configured the peer with rsa-signature and only the client-certificate.
On Server i used both certificates.
Also i tryed to play arrond with fqdn and address without success.
Would be fine if anybody can help here.
IPSec with Certificate is really needed!
thanks
n4p
Thu Dec 20, 2018 8:31 pm
Nobody with an idea?
JohnTRIVOLTA
Thu Dec 20, 2018 10:19 pm
Hi
Just try , use IKE2 with auth. method RSA Signature with check off certs key usage ipsec tunnel, user, end system!
Users browsing this forum: Baidu [Spider], DeCoen, Google [Bot], rmozoster, rogerlie and 137 guests
