MUM Europe 2020
Rey68
Ipcloud two Mikrotik
Sun Dec 16, 2018 3:23 pm
Hello:
I have two mikrotik, one like wan and wifi, and another as a repeater of the wifi (using wlan).
The first I can access remotely through xxxxx.sn.mynetname.net.
But the second one does not, I understand that it is behind NAT, as indicated by IPcloud in the second.
Try making a NAT rule to the ip of the second router 192.168.1.30 and calling xxxxx.sn.mynetname.net. with a port.
But it does not work.
How should I do it?
sebastia
Re: Ipcloud two Mikrotik
Sun Dec 16, 2018 4:06 pm
Hi
You should take care of following
* make dst-nat rule to port-forward traffic from first MT to "repeater"
* ensure that this forwarded traffic is allowed in first MT (with default config should be ok, as there all dst-nat-ed traffic is allowed)
* allow the incoming connection on the "repeater" MT
Rey68
Sun Dec 16, 2018 7:30 pm
I have this rule in mikrotik 1 (wan).
action=dst-nat chain=dstnat dst-port=8292 in-interface=ether1 protocol=tcp \
to-addresses=192.168.1.30.
¿is correct?
allow the incoming connection on the "repeater" MT.
I do not understand this. The second mikrotik have acces to internet
sebastia
Mon Dec 17, 2018 11:07 pm
"action=dst-nat chain=dstnat dst-port=8292 in-interface=ether1 protocol=tcp to-addresses=192.168.1.30"
* that's the port forward
* have you check the firewall filter table and forward chain?
* and lastly does the target device (192.168.1.30) allows connection on the 8292 port in filter input?
Rey68
Thu Jan 24, 2019 4:45 pm
Solved!.
I change in second mikrotik port Winbox in Ip service, xxxx.
I create nat in 1º Mikrotik to ip with port in second mikrotik winbox
In winbox enter with xxxxx.netname.net:xxxx
erlinden
Thu Jan 24, 2019 4:49 pm
Why not do it properly and run a VPN service? Are you aware that there was (and still is depending on the version of RouterOS you are running) a huge security issue?
Rey68
Thu Jan 24, 2019 5:05 pm
Is there a security problem with winbox?
So using Ipcloud is not a good idea?
AlainCasault
Trainer
Trainer
Thu Jan 24, 2019 5:25 pm
It's more a question of having an open port to exploit, two in your case.
And with a VPN, you can have proper routing and all your tools will work as if at home (or at the office).
___________________________
Alain Casault, Eng.
If I helped you, let me know!
anav
Thu Jan 24, 2019 5:30 pm
Concur, if you want to remotely access winbox on either unit, using an open port approach is cwazee stupid.
One method used, is called port knocking however the VPN connection approach is superior.
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
Rey68
Thu Jan 24, 2019 6:08 pm
I understand, I will create a vpn service
Users browsing this forum: angriukas, HB1 and 114 guests
