MUM Europe 2020
satman1w
IP Cloud question
Mon Dec 17, 2018 11:48 am
What is happening with IP Cloud? None of my routers are able to update their addresses.
mynetname.net cannot be resolved....
Since a few of my tunnels depend on this, I would like to know, what is happening.
nslookup says:
Code: Select all
C:\Users\user>nslookup mikrotik.com
Server: google-public-dns-a.google.com
Address: 8.8.8.8
Non-authoritative answer:
Addresses: 2a02:610:7501:1000::2
159.148.147.196
C:\Users\user>nslookup mynetname.net
Address: 8.8.8.8
DNS request timed out.
timeout was 2 seconds.
*** No internal type for both IPv4 and IPv6 Addresses (A+AAAA) records available for mynetname.net
joserudi
Re: IP Cloud question
Mon Dec 17, 2018 12:00 pm
I have the same problem. +1
engmohamed01
Mon Dec 17, 2018 12:02 pm
I have The Same ,
any one can help ?
const
+1 russia
gotsprings
Forum Veteran
Forum Veteran
Mon Dec 17, 2018 12:19 pm
Seen this since Friday. Would really appreciate and update.
"It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
Mark Twain
R1CH
Forum Veteran
Forum Veteran
If you use an old RouterOS version, the service no longer works. Make sure to update your RouterOS, stop the IP cloud service then start it again.
EDIT: Actually it seems like a service outage, ns1.kissthenet.net and ns2.kissthenet.net are both failing.
satman1w
Mon Dec 17, 2018 12:46 pm
Never mind the router and the ROS version (which is updated to actual revision btw...) but none of the DNS servers including 8.8.8.8 cannot resolve "mynetname.net"!
that is the problem !
engmohamed01
Mon Dec 17, 2018 12:50 pm
when i try to ping from https://network-tools.com/
its give me
Unknown error: 1214
Unknown error: 1214
Unknown error: 1214
Unknown error: 1214
Unknown error: 1214
Unknown error: 1214
Unknown error: 1214
Unknown error: 1214
Unknown error: 1214
Unknown error: 1214
engmohamed01
Mon Dec 17, 2018 1:09 pm
its working fine after update now .
dirtonth
Trainer
Trainer
Mon Dec 17, 2018 1:34 pm
We have customers complaining about same issue...
nescafe2002
Long time Member
Long time Member
Mon Dec 17, 2018 1:35 pm
mynetname.net has no A or AAAA records defined, as your nslookup reveals.
Try [your_serial].sn.mynetname.net instead:
C:\>nslookup 000a09000195.sn.mynetname.net ns1.kissthenet.net
Server:  UnKnown
Address:  2a02:610:7501:1000::201
Address:  82.x.y.z
nmt1900
It seems to be "intermittent" problem - sometimes resolution of sn.mynetname.net works and sometimes it returns SERVFAIL...
dirtonth
Trainer
Trainer
Mon Dec 17, 2018 1:41 pm
satman1w
Mon Dec 17, 2018 2:15 pm
You are missing the point!
How exactly will I help google dns to be aware of mynetname.net if I upgrade router ??
The problem is that domain is not resolvable! None of the DNS servers are aware of it.
ok?
normis
Mon Dec 17, 2018 2:20 pm
It will help. Because new RouterOS has a completely different Cloud implementation which uses DIFFERENT DNS SERVERS on MikroTik side. Please do what was suggested.
jrjr
Mon Dec 17, 2018 2:34 pm
On my own house router, with the latest long term version 6.42.10 it is was not working.
I tried with diferent dns servers on the router and rebooted the router several times and it still was not working
Them I updated to the latest stable version 6.43.7 and it started to work.
Best regards,
qostechgl
Mon Dec 17, 2018 2:37 pm
is this official? any device with firmware below 6.43 will no longer be able to update ip with cloud ip?
QOS Technologies Inc.
Montreal, Canada
www.qos.tech
driven
Mon Dec 17, 2018 2:44 pm
If you updated the implementation of the cloud service, why is the entire long-term branch broken including the latest release?
mpadmin
Mon Dec 17, 2018 2:46 pm
Same problem for all my routers on dynamic IP addresses (all using RouterOS 6.42.10). My monitoring system are showing them down, DNS names cannot be resolved.
Since one week Cloud was very unresponsive (with many timeouts), today it just completely stop. Here is the NSLOOKUP results:
> server 8.8.8.8
Default Server:  google-public-dns-a.google.com
Address:  8.8.8.8
> XXXXXXXXXXX.sn.mynetname.net
Address:  8.8.8.8
*** Request to google-public-dns-a.google.com timed-out
Maybe the problem is with the long-term version only?
mkx
Mon Dec 17, 2018 2:48 pm
As @normis hinted: problem is there for devices with ROS <= 6.42 ... devices with ROS >= 6.43 are OK.
BR,
Metod
dirtonth
Trainer
Trainer
Mon Dec 17, 2018 2:52 pm
Normis,
We do not understand what's the resolution to this problem. We have a number of customers reporting issues this morning. Their mynetname dns is not resolving from anywhere. Their router (IP>Cloud) sometimes manages to update the ip, and some reports "Failed", but either or, their IP is not resolving when we ping the full hostname ([*sn*].sn.mynetname.net).
Please let us know what we should inform the customers to do.
mpadmin
Mon Dec 17, 2018 3:07 pm
OK, but all my routers are using RouterOS 6.42.10 (long-term) and I want to keep it that way. I need stable IP cloud service too.
qostechgl
Mon Dec 17, 2018 3:11 pm
Same situation here with 6.42.10 long term supporr... This needs to be fixed asap
Montreal, Canada
www.qos.tech
satman1w
Mon Dec 17, 2018 3:46 pm
Hi Normis,
But I did! My routers are all on last stable revision of ROS.(6.43.7)!
If everything works fine I should be able to resolve domain regardless of the specific router and I am unable to do so, whatever DNS server I use!
I have pasted the lookup answer in my fist post.
"No internal type for both IPv4 and IPv6 Addresses (A+AAAA) records available for mynetname.net "
regards
TedjeVanEs
Mon Dec 17, 2018 3:55 pm
I’m 12 hours flying away from that router. I need mynetname to be up to even access it. When wil cloud dyn dns be up again?
In love with RB951G-2HnD, but she's not easy to please
koolandrew
Mon Dec 17, 2018 4:09 pm
I am having the same issue. None of my routers using the cloud service are up, and many have a dynamic ip address; hence the need to use it, so i cannot even support it.
Pleaes make an announcement regarding this.
normis
Mon Dec 17, 2018 4:21 pm
Users browsing this forum: lambert, vilpalu and 136 guests
