deanMKD1
Wrong RoS version noted after upgrade to 6.43.4 Stable
Mon Dec 17, 2018 11:45 pm
Hi Mikrotik Developers
Noted one weird thing today after flashed my hAP AC2 router. To explain with image for what i talking about
into System > Packages
Into System > Routerboard
Anyone know why is showing wrong current firmware?
parham
Re: Wrong RoS version noted after upgrade to 6.43.4 Stable  [SOLVED]
Mon Dec 17, 2018 11:56 pm
In the last photo press the upgrade and then wait 5 sec then reboot.
You are running on 6.43.4 as ros, but the hardware firmware need to update too.
deanMKD1
Tue Dec 18, 2018 12:01 am
I dont knowed that even RoS must upgrade hardware FW. Thanks for your answer. Helped !
mducharme
Trainer
Trainer
Tue Dec 18, 2018 4:09 am
You can upgrade firmware automatically after ROS upgrade by going into Routerboard->Settings and enable auto upgrade. Second reboot will be needed after ROS upgrade for firmware upgrade, but it saves you from needing to click the upgrade button.
Users browsing this forum: Bruzxce, Dasi, Google [Bot], seriosha, sindy and 227 guests
