Redmor
6.43.8 UPDATE ALERT READ BEFORE UPDATE
Fri Dec 21, 2018 10:11 pm
Something that MikroTik forgot to write in changelog that is more important than everything else:
If you had set a country and use frequency mode superchannel, updating to 6.43.8 will set regulatory domain.
What does this mean? If you don't use frequencies in default scanlist, you are going to lose stations.
Set country to no_country_set before upgrading.
P.S. Thank you MikroTik, instead of TDMA REAL improvements or a new Dude, a present that is a pain in the a*s.
filipelias
Re: 6.43.8 UPDATE ALERT READ BEFORE UPDATE
Fri Dec 21, 2018 10:54 pm
This can't be real!
Odesláno z mého XT1635-02 pomocí Tapatalk
petrb
Fri Dec 21, 2018 10:59 pm
Yes, this is real. :( omg .... where are you going MikroTik ... highway to hell
Did you read manual? .... What? .... Read the manual.
hapi
Fri Dec 21, 2018 11:12 pm
true... true
r00t
Fri Dec 21, 2018 11:57 pm
thanks for heads up... it would really suck to upgrade now before Christmas to this version and break everything
anav
Sat Dec 22, 2018 12:45 am
I was going to believe the OP due to his credentials at the bottom of the post but then I saw he was from Italy, and had second thoughts, probably steering his ferrari with his left foot while checking out his WINBOX connection with his Iphone 10 in one hand and drinking wine out of the bottle in the other hand :-)
Just kidding, just would love to be in Italy with such minor problems. Merry Christmas or whatever holiday you take part in this time of the year!
Thanks for the heads up!
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
MTUNA Certified, by the Ascerbic Llama!
Redmor
Sat Dec 22, 2018 2:56 am
You call it a minor problem? Probably you aren't using MikroTik for wireless
anav
Sat Dec 22, 2018 2:58 am
Well I do have two CapACs, but I am holding off upgrading until mikrotik responds. Thats why I said Thanks!!!
I fear they are already into the schnapps because they have not responded. :-(
Although Normis should not be in his temporary red shelter (I mean car) intoxicated. :-)
Redmor
Sat Dec 22, 2018 3:04 am
You can always remove country before update, I'm not worried about this decision, but at least it should be written somewhere in changelog: "Disabled superchannel for countries, only regulatory domain for them".
anav
Sat Dec 22, 2018 3:09 am
I am very unfancy with wireless with only two capACs I do not even use capsman.
Also each one has
wlan1 = 2.4ghz for smart devices
wlan2 = 5AC for a. home wifi and b. (virtual) VWLAN for guest wifi
In both 2ghz cases on vlan
In both virtual VWLAN cases on vlan
Not sure if upgrade will affect them as I have no idea what superchannel is??
Canada has limitations on 2.4ghz for example. My AC is using Ceee 20/40/80
Redmor
Sat Dec 22, 2018 3:26 am
Also each one has
It's Frequency Mode in wlan settings, you can upgrade without problems because you don't use superchannel for Wi-Fi (phones and PCs won't connect).
You're using regulatory domain, I'm 99% sure.
You would have problems after upgrading if you have antennas on towers connected to other antennas, no need to worry for indoor APs.
normis
Sat Dec 22, 2018 1:23 pm
Using "country" means you want to folow regulatory domain restrictions.
Using Superchannel is exactly the opposite.
Why would you want both at the same time? "Country" setting was always meant to limit your frequencies and power, to follow country regulations (law).
Users browsing this forum: jmszuch1, pe1chl, scoutadmin, sealouiw, Semrush [Bot] and 52 guests
