ashisheitl
Transperent Proxy
Tue Mar 06, 2007 4:43 am
I have installed MT 2.9.27 as a MAin Distribution server. Now i want to install Proxy which should work as a transperent proxy.
I need a help for configure the same.
I have also refer the web proxy topic in reference, but confused in some points. Also need HTTP caching.
exebug
Tue Mar 06, 2007 7:07 am
ashisheitl
Wed Mar 07, 2007 8:38 am
Thanks Its working fine, But Now if i will deny shome web pages like rapidshare and some user tring to open the website, It is showing that ACCESS DENIED.
I dont want that this type of MSG at customer END.
How to do that
Znuff
Wed Mar 07, 2007 10:36 pm
then don't block those websites
if you're an ISP that's probably against the law
ashisheitl
Thu Mar 08, 2007 7:09 am
MAN,
Read the Q carefully, I mean to say, i dont want to show the STANDARD MSG, which is showing.
I WANT TO SHOW SOME OTHER MSG.
Is there any way to CHANGE the STANDARD MSG.
sergejs
Thu Mar 08, 2007 8:22 am
'redirect-to' option might be used for proxy access list, it option allows to redirect user to the specific web-page, when he/she is requesting the particular page.
savage
Thu Mar 08, 2007 10:03 am
Make your life easy. Put in a dedicated linux machine running Squid, and make/break/configure squid to do exactly what you want.
MT's internal proxy is really limited, and cannot do what you want.
Regards,
Chris
ashisheitl
Fri Mar 09, 2007 8:29 am
Sir,
Can u explain me how to do it in MT...Please
Users browsing this forum: Google [Bot], MSN [Bot] and 41 guests
