MUM Europe 2020
Equis
Forum Veteran
Forum Veteran
Can't login using winbox after upgrade to 2.9.40
Tue Mar 06, 2007 7:20 am
Hello
After upgrade I can't seem to logon via wlan using winbox.
I can mac telenet and have web access,
Any Idea's?
"Edited for clarification"
janisk
Tue Mar 06, 2007 8:21 am
you cannot login using winbox or wlan? or both? please be more specific
Equis
Forum Veteran
Forum Veteran
Tue Mar 06, 2007 8:33 am
I edited the post.
I cannot use winbox to logon to the system via the systems wlan port.
I have not tried the ether ports as its a remote box
janisk
Tue Mar 06, 2007 8:44 am
delete winbox and application data for winbox, download new one and try again :), some files became corrupted. usually cleaning them out helps
Equis
Forum Veteran
Forum Veteran
Tue Mar 06, 2007 8:51 am
Hello, Thanks
This was 2 diffrent PC's
I'll download fresh one anyway but it does not even connect at all
Users browsing this forum: faxxe and 95 guests
