WirelessRudy
How to block Second (Unknown) DHCP server on network
Thu Mar 08, 2007 2:26 am
I have a network with Hotspot set up. Most works fine but at times have clients that play around with their ADSL routers from previous providers and they use only the LAN side to connect to my network and their PC. Usually by default most of these have DHCP server enabled. Off course does my network also have DCHP server enabled and on top of it does the Hotspot system also wants to assing ip adresses.
This (unknown for me) second DHCP server obstructs my network and legitimate client that re-associate get different network ip´s assigned and can´t log into the hotspot any more. It also creates at times network storms wich brings the whole network down.
It need hours to trace down where to find the illegal DHCP server. Is there no way to block illegal DHCP server in general?
Znuff
Thu Mar 08, 2007 2:34 am
First of all you should set up your DHCP server as Authorative, most ADSL routers with dhcp obey that flag.
WirelessRudy
Thu Mar 08, 2007 12:32 pm
Authoriative is on by default, with 2 secs delay. Still have that problem.
Actually, if I read up in the reference manual it explain the dhcp server will wait now for 2 secs for the client to come back with an ip request again. If it has been assigned an ip from another dhcp server it will not come back. So then the clients doesn´t get an ip from my server?
But actually the explanation in the ref. manual doesn´t make sense to me.
Any other suggestions?
Znuff
Thu Mar 08, 2007 9:35 pm
Remove the 2seconds delay, there's no need for that.
Mayssam961
Re: How to block Second (Unknown) DHCP server on network
Thu Jan 06, 2011 8:06 pm
was that problem fixed buy removing delay ? because i have the same problem ...
Thanks a lot i would really appreciate any help , thanks
Think Before You Print.
fewi
Thu Jan 06, 2011 8:17 pm
Implement CPE firewall rules that block customers from acting as DHCP servers on your network.
DHCP servers reply sourced from udp/67 to udp/68. Block that traffic on the customer facing port.
Specific answers require specific questions. When in doubt, post the output of "/ip address print detail", "/ip route print detail", "/interface print detail", "/ip firewall export", and an accurate network diagram.
Mayssam961
Sat Mar 19, 2011 6:18 pm
can you please post guide how to add that rule ?
or example ?
please any hints?
fewi
Sat Mar 19, 2011 7:12 pm
http://en.wikipedia.org/wiki/Dynamic_Ho ... n_Protocol
That explains DHCP traffic flow. Block it where appropriate. For example, apply the following rule to the CPE interface facing your network:
add chain=forward out-interface=WAN protocol=udp dst-port=68
Now the client cannot send DHCP offers through the CPE to your network.
sup5
Sun Mar 20, 2011 12:40 am
Don't fight the caused problems.
Avoid the root of the cause.
ie.:
DonÄt do weird firewalling
Instead apply proper user isolation.
VLANs, EoIP/VPLS Tunnels and Horizon Bridging/Private VLAN Edge(PVE) are your friends.
A proper Port/User Isolation only allows the clients to communicate with your Hotspot.
A communication between the clients is NOT possible. Thus meaning a fraud DHCP-Server won't affect the other users.
This way you also will be able to supress MAC-Spoofing, which a user can abuse the steal another user's Hotspot session.
There is absolutely no need to do weird firewalling at the users site.
sooli
Wed Mar 13, 2013 10:50 pm
ie.:
any example to isolate users on local area network using hotspot?
Users browsing this forum: Google [Bot] and 65 guests
